Question about Gaggenau Dishwashers
When i start the dishwasher, there is a humming sound but there is no water coming into the dishwasher to wash. model number is: G1924-160, it was bout in april 2000. only one problem since, in 2005 where the pump was tested and the debris was removed.
  • Gaggenau Master
  • 2,605 Answers
Hello, welcome to FixYa.
Based on your description, "there is a humming sound but there is no water coming into the dishwasher to wash
"...the issue is likely with the inlet/water valve. I'm not sure if you are aware of it, but this machine is built by Bosch (B/S/H/).
**To remedy this you will need to check and possibly replace the valve**
This is what to look for..i.e.
As long as your model number is indeed correct, this info below will be accurate.
Original part is # 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it or to check for debris in the filter/screen at the inlet is pretty straight forward. Here`s how...
1) undo the water line. ( here you can visually inspect the screen in the valve...if nothing noted, you'll likely need to replace it as follows )
2) Remove the two #20 torx screws fastening it in place.
when i start the dishwasher, - 156e176.jpgttp://i.fixya.net/uploads/images/156e176.jpg" alt="156e176.jpg" class="h_mi" />
3) the feed tube to the machine at the back of the valve and swap it with twhen i start the dishwasher, - 5937279.jpg
and
Once the new one is in you should be good to go. Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
Posted on May 26, 2011
  • Jill George Jul 30, 2012
    Hi, we have the same problem, different model. Model # GM 915-710. What should we do?
Buttons on the dishwasher's control panel is not working. When starting a "normal" load, it switches to "clean" and does not start the wash.
Hello. Most likely, the humming sound you hear is a jammed drain pump which is activated immediately to pump out any stale or standing water below the level which you can see. Then, fresh, hot water enters the tub to start washing the dishes. I need the model number and exactly what lights are blinking--those blinking lights are error codes(combinations of 2 or more lights, one light blinking a certain number of times, then blinking again, a different number of times--ex 3 times, then 7 times) the lights blink a binary error code--thats why I need the model number to look up the code on the chart
Sep 10, 2015 | KitchenAid Dishwashers
Turn dishwasher on . the water loads in and then goes into wash cycle, it does it's wash cycle then drains and will not load clean water for rinse cycle it just hums a and then quits, then tries again and...
Tim Derbowka, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Tim Derbowka), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool GU2300XTS 24 in Builtin...
Loud humming just started during wash cycle
Humming can be simply due to a mechanical vibration when the wash pump is running. Alternatively it could be the sound of the detergent door solenoid which might be stuck.
Will need make and model number of dishwasher to give further advise. Does the dishwasher complete the cycle and drain out the water?
Feb 13, 2011 | Dishwashers
No water
Check the incoming water to the dishwasher. If the filter is clogged clean it and re fix. Strainer is located on the machine inlet junction where the hose is fitted.
The humming sound is due to motor running without water. When you rectify the inlet flow fault, pour additional water manually into the wash chamber and run the cycle. This to remove trapped air in the pump due to dry run.
May 28, 2010 | Caloric 24 in. CDU300C Built-in Dishwasher
I have an kenmore elite "ultra wash" model 665. not sure the rest.. about 7/8 years old, making loud buzzing sound during wash cycles,starts about 5 minutes into the normal wash cycle. i removed the inlet...
I have the same problem as those who stated their dishes are not getting clean. If you listen to the wash cycle you should hear water sloshing around inside. If you hear just a humming sound the washer has no water. I have this problem. I had a tech come and he told me the water is syphoning out my drain and I need to change my plumbing, then he charged me $65. I have lived in this house for ten years. 6 with the washer that came with house and 4 with this Kenmore Elite. This problem started about 6 months ago. So what I have been doing is opening the door, after the humming starts and the sloshing stops, and adding about 2 L of water. It seems to wash just fine after that.
Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
LOUD HUMMING AFTER WATER FILLS AT START OF CYCLE
Sounds like you have something in the sump/motor. I could lead you through it on a chat session but too much just to type. Let me know if you would like me to do so.
Mar 04, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwashers Logo
282 people viewed this question
Top Gaggenau Dishwashers Experts
Are you a Gaggenau Dishwasher Expert? Answer questions, earn points and help others
