Question about Mtd Garden
Looking for the repair manual (shop) for the 1P61NO engine. I need to set the idle and run for the mower.
3 Suggested Answers
  • 407 Answers
SOURCE: I have a Bolens 22"
There will be a small screw near the carb with a spring around it.That is the idle screw.Turn it left to increase the speed.
Thank You for using Fix Ya.
Posted on Jun 04, 2011
vincob
  • 718 Answers
SOURCE: How do you remove the engine from a Toro SuperPro
Try looking under the machine there should be four bolts that mount the engine to the frame. Good Luck...
Posted on Aug 29, 2011
How do I ge ta repair manual for Honda HRU19 mower? The mower has no power when hot and will not start. If I had my choice again ...wouldn't purchase mower with automatic choke. Thanks
Your wanting the engine repair manual instead of one for the whole mower. The owners indicates that it has a GCV160A0.
You can download a shop manual from the following
Shop manuals Honda Engines
but if your wanting a full service manual then you need to order from Honda. The site can direct you to one online sites.
Honda Power Equipment Honda Generators Lawn Mowers Snow blowers Tillers
Jan 11, 2015 | Honda Garden
Looking for a 445677 Free Repair manual
I don't know about a free one..but try eBay and put your model and manual there are many in there...but before you try that try adjusting your carb..out of adjustment air/gas mixture acts that way also..locate the adjustment screw and at about half throttle adjust it clockwise until it starts to bogg down the the other way until it Boggs again..keep adjusting back and forth until the engine runs the smoothest then add some throttle and repeat if it needs it...good luck..
May 17, 2014 | Briggs & Stratton Garden
My mountfield hp164 petrol mower starts but wont run smoothly even when the engine is warm it is constantly idling erratically
Check sparkplug ie remove and clean. Set gap normally 1mm. Check s/p lead has firm connection. Check manual for correct fuel requirements. Other wise take it to the mower repair shop. It's not worth your time to muck around with it. Too frustrating!
Apr 17, 2013 | Garden
Low RPM's
I know this is an old post but I figure maybe my solution will be found by someone else doing a Google search and it can help them. Hopefully, you've gotten yours fixed in the 10+ months since you asked this.
Anyway, if you remove the top plastic shield from the mower (two screws hold it in place, plus a small cover near the air filter that needs to be removed) you will see a small spring that attaches to a tab at the front of the mower. If you bend that tab forward it will put more tension on the spring and increase the engine speed. You'll know if you are looking at the correct spring if you lightly press on the spring and the engine speed increases.
It is a good idea to monitor the adjustment with a tachometer. My owner's manual says the engine has a 3,100 max rpm. You don't want to set it above the specified rpm or you'll probably burn the motor up in a short time. I set mine at 3,060 rpm. It's hard to get it perfect but I figured slightly low is better than too high. Mine had been running at 2,800 rpm.
I bought a small engine tach on eBay for around $9. The wire wraps around the spark plug wire 4-5 times and then you can read the engine speed. It also keeps track of how many hours the engine has been running. I figure that will come in handy for oil change intervals so I permanently mounted it to the mower. It almost looks like it came that way from the factory. :-)
Here's the tach I bought: Hour Meter Tachometer 2 & 4 Stroke Small Engine
Aug 26, 2012 | Craftsman 675 Torque 190 cc 21" Push Lawn...
My YT model 28857 24hp engine Lawn Tractor runs rough and surges up and down when at idle. I just bought this tractor, 8-8-2011 Is there a carburetor adjustment to smooth out the engine idle? Will this...
The carburetor is most likely dirty and needs cleaned. Dirt can get in there from the gas can. Check the fuel tank. Is this a new mower? If not check the air filter, it will also cause this to occur if it is stopped up.
I hope this helps get you running again.
Aug 10, 2011 | Garden
Rpm fluctuates idles high then low high then low
It could be the governor spring is weak. Get your model type and code numbers off the engine shroud and take them to your local small engine repair shop and get the new spring. It's not hard to replace. Install the new one and you should be up and running.
roundo4
May 23, 2010 | Mtd 22" Yard Machine Push Mower
Briggs and stratton mower will start but will not run and when it does run it is very high idle
lots of things it could be........check the obvious first
1.....throttle butterfly to see if it had come out of the carburetor
2.....check static governor settings. to set rotate carb to wide open throttle, loosen governor arm and rotate it to the right, tighten jam nut, if it still runs away then you have a blown governor inside the mower
3..... check for unhooked springs and linkages
hope this helps and good luck the above 3 things to check is 90 percent of all my repairs in the shop when it comes to the engine running too fast
see ya!
Nov 23, 2009 | Briggs & Stratton Garden
Going dead atfer fuel system simple repair.
Try checking the carburator, spark plug/wire, idle setting, tightening all the hose connections, and, maybe check the manual's trouble shooting guide, and if you still have problem with your mower, try and find a good repair shop and have them diagnose the problem.
Hope this helps! :)
Sep 06, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mower deck not running
You model requires a clutch switch not a relay switch. take it back and bring them your manual on the tractor and help them find out what you need.
Jul 10, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mcculloch chainsaw 2416
All you have to do is call 1-800-521-8559 and select U.S. then select the parts department, have your model number ready and ask them for a PDF of the owners user manual to be emailed to you, they will normally be sent in 1 hour for free.
Aug 03, 2008 | McCulloch MC1275 Steam Vacuum
Garden Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
