Question about Sony Ericsson "Equinox" TM717
TM717....phone turns on, but screen has a light shadow behind of it...half the screen is total black and the other half you can see light behind it. None of the keys do anything when pressed. It worked fine in the morning...had in my pocket and took out two hours later and the screen was dark and not functioning.
  • 4 Answers
Throw it 2 dustbin
Posted on May 26, 2011
  • kennethkl280 Sep 01, 2011
    My tm717 has done virtually the same thing. I am amazed that dropping the phone once can cause this to happen especially since the idea of a cell phone is to be mobile. I think we should start a class action law suit against Sony.
K850i red light turn on when charger or usb cable plug in & the phone does't start
I just bought a T303 Sony Ericsson I pluged it in to recharge it and a red light come on but no light come on the screen when Iunplug it from the charger.
Aug 22, 2013 | Sony Ericsson T303 Mobile Phone (Shadow...
Nokia supernova 7610 phone screen has gone black
Your mobile screen connector point must be having loose or a faulty screen. Best it will be to take it to the servicing center.
Thank you for asking on fixya.com
Mar 20, 2013 | Nokia 7610 Supernova Cell Phone
Hpw2408h screen problems
if the half portion of the screen is only black shadow the the cause is either busted screen back light or a dry connector at the power inverter board. to access this part you will need to remove the back cover of the tv unit. the power inverter board installed near the power supply board and then the screen back light is mounted at the upper and lower portion of the panel display covered with metal shield.
Nov 12, 2012 | HP Televison & Video
I need a code to unlock sonyericsson tm717
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Sep 18, 2012 | Sony Ericsson "Equinox" TM717
Well i don,t know what i did but there appeared light color of light black back ground i can not remove this background picture how do i shut it of thank you.
U turn to another channel,now it look like u have a picture of a shadow behind it?Yes,than u have freeze a picture on the tv for a long,might have a tv screen burn in.Tries go into tv menu go to colors setting.Tries contrast setting all the way up to maximum.Tries colors a third of a setting.The brightness half of it setting.Should or might help to solved this problems.
Dec 06, 2010 | JVC AV-32D305 32" TV
Cellphone - black screen
There is a LCD strip (Bunch of closely punched wires, that makes up a connector). If you have replaced the LCD yourself them there may be chances that the strip is not properly punched. That strip comes out of display and goes straight onto the main circuit board.
This is a common issue that makes the Phone works perfectly but in a black-out mode.
I hope you have a clear picture now.
Regards, Waqar. If I was helpful, Kindly do Rate!
Oct 12, 2009 | Cell Phones
Samsung 2006 56" HLR5688W DLP TV Right half of screen turns black. Left side normal picture. Corrects itself when set is turned off and back on. Randomly occurs - sometime picture is ok for half a day...
Possibly a bad light tunnel assembly if the part is only a shadow effect. If not then probably a bad DMD board. The DMD board is part of the light engine but needs to be replaced by a technician.
Aug 15, 2009 | Samsung Televison & Video
Blue shadows & black screen with flashing red light
Your problem is the convergence IC's (part number STK392-110). They will need to be replaced as well as matbe a couple of burned resistors that will be right by the IC's. Due to the complexity of this repair as well as the alignment required after the parts are replaced. you may want to contact a tech. Let em know if I can be of further assistance. You can find a local tech by going to the homepage of FIXYA and inputting your zip.
Dec 22, 2008 | Televison & Video
Sony Ericsson "Equinox" TM717 Logo
230 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
