Question about Caterpillar Remote Control Skid Steer Big Builder
TREK TRUCK TOY DOES NOT GO FORWARD THOUGH MOTOR IS TRYING
Is there no reverse, just forward?
only forward gears no reverse Dolls, Playsets & Toy Figures ...
www.fixya.com > Forum > Tags > only forward gears no reverse
Ask your only forward gears no reverse doll, playset and toy figure questions. Get free help ... Could there be a problem in both of the drive motors themselves?
Ertl only forward gears no reverse Dolls, Playsets & Toy ...
www.fixya.com > ... > Dolls, Playsets & Toy Figures
Ertl dolls, playsets & toy figures only forward gears no reverse related ... as i drive itforward What is the last thing that happened before you noticed there was a ...
Farmall only forward gears no reverse Dolls, Playsets & Toy ...
Farmall dolls, playsets & toy figures only forward gears no reverse related questions and answers. Ask your Farmall questions. Get free help from doll, playset ...
PREVIEWSworld - Devolution Goes Forward In Reverse
www.previewsworld.com/Home/1/1/71/979?articleID=170370
I had just started doing Fear Agent and Strange Girl and a number of other ... But in terms of this there was some rule-breaking that I'm not sure I would do today ... Elliott Serrano: Okay, what would be one toy or action figure that you'd like to be ...
Dec 16, 2015 | Toys
6x4 gator transmission grinds in forward and reverse
identify which wheel its coming from, remove the motor from the gear box and then run the motor and see if the motor grinds, if not then you have a bad gearbox
Oct 19, 2014 | Peg Perego John Deere Gator HPX Ride on...
My Polaris 24 volt power ride on toy when put in reverse would go forward. When shifted in drive would go in reverse. Now it does nothing. Can anyone help?
remove the rear tires, then pull out the gearboxes and motors and use a multimeter and see if you are getting any power to the motors, then post back the results
Jan 26, 2013 | Toys
Wont go forward only reverse
try switching the wires on the motors and see if it goes forward then
May 05, 2011 | Fisher Price Power Wheels Kawasaki KFX...
My foot hits the front wheel when turning
Without much to go on, it sounds like the bike may be a bit too small for you. If it's too late to take it back for a large size, there are a couple of options for you.
1. Buy a set of pedals with toe clips. These will position the pedal under the ball of your foot and keep your feet from sliding forward into the wheel. 2. You may also be able to buy a set of shorter cranks, which are the arms your pedals attach to. Your Trek dealer can advise you as whether these are available for your bike and how much it will cost. Crank length has an effect on the effort required to pedal, though, so make sure you've tried everything else first.
Jan 10, 2011 | Trek 7100 WSD
I bought this yesterday and the moter in the back that balences it stopped working... how do i fix it
will need multitester to see if motor is receiving power when you use the forward stick. if the motor is receiving power then the motor will need replacing. Motor slids in and out. Can get motors on ebay quite cheap.
Jul 28, 2010 | SYMA Toys industrial New Syma S107 Mini...
Gator goes forward in reverse and reserve in forward. Battery is hooked up correctly
there should be a wire harness on the back of the shifter to go forward and reverse try to switch it around
Apr 19, 2010 | Peg Perego John Deere Gator HPX Ride on...
Caterpillar Remote Control Skid Steer Big Builder Logo
20 people viewed this question
Top Caterpillar Toys Experts
fordexpert
DROPNDEAL
DROPNDEAL
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
