MY SD CARD WON'T LET ME PUT PICTURES ON IT FROM MY COMPUTER. IT SAYS IT IS WRITE PROTECTED. THE CARD IS NOT LOCKED. AND ALL MY CARDS SAY THE SAME THING. WHAT DO I DO.
  • 661 Answers
Hi brenda28152 ,
This seems to be a problem where the write protect switch on your memory card in is on position.
The write protect switch disables the write feature from your flash drive or memory card, which means that you would not be able to put anything on your flash drive including pictures.
Therefore all you need to do is change the position of the write protection switch so that it's disabled and not write protected , and there you go , you can write files on your flash drive.
Please find the below images for more description , MY SD CARD WON'T LET - sajjad4help_1.jpegsajjad4help_2.jpeg
In case your problem in not solved do feel free to get back to me..
Hope this helps ..:) your feed back would be appreciated.
Posted on May 26, 2011
Camera takes pictures unless I put in the memory card then it won't
What type and size memory card? The C653 works with MMC and SD cards, 2GB or smaller. Even though SDHC cards will fit into the slot, they are electronically incompatible and will not work.
Apr 15, 2013 | Kodak EasyShare C653 Digital Camera
When i remove the sd card to upload photos to my computer my new pictures are not there but are when the sd card is in the camera?
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked).
Hope this helps.
Feb 02, 2013 | Fujifilm FinePix S4250 Black 14MP Digital...
When I put in a Verbatim SDHC 4GB into the modem it won't do anything.
Apparently your device (do you really mean a modem, or is it a card reader) isn't SDHC-compatible, only SD-compatible. SDHC cards have an electronic incompatibility and will only work in devices specifically designed for them.
Dec 18, 2012 | Cameras
Sd card trouble
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 29, 2011 | FUJIFILM CD-R Storage Media
My memory card in my canon camera suddenly won't let me take or delete pictures because it says card locked. - have been using it without a problem but then today it suddenly said "card...
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards.If youare getting a memory card locked message then check this out.
How to UnlockSD Cardheatman101
Aug 04, 2011 | Cameras
My camera is tellling me Memory card is write protected, won't let me take pictures siince I downloaded pictures onto my computer?
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 13, 2011 | Nikon COOLPIX S700 Digital Camera
Memory card slot issues
try to take a look on the SD card itself. there should be a notch on the side that say "locked" slide it up/down to unlock.. The term SD means "secure digital" meaning the SD card can be locked as to accidental erasures..
Feb 14, 2010 | Compaq Presario CQ60-220US PC Laptop
Camera says this card cannot be used on power up.
either the card is not supported or it needs formatting
Nov 25, 2008 | Nikon COOLPIX L5 Digital Camera
Vvicam 3625 does not working with windows XP
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 27, 2008 | Vivitar ViviCam 3632 Digital Camera
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
