Question about Craftsman StaplerBrad Nailer All Purpose EasyFire Forward Action
My Craftsman Stapler/brad nailer jammed and I had to take it apart to clear the jam. Although trying to be careful to not dis-assemble any more than necessary something slipped then something else moved and now I have a pile of parts. Is there any place/way to get assembly instructions or prints that would allow me to re-assemble the tool? Too many parts that don't have a logical order of assembly for me to figure out.
  • 4234 Answers
SOURCE: air stapler leaks air through ''nose''
This sounds like one of the O-rings has failed. Yes it can be fixed. Check to see if HD has an O-ring kit for these guns. That kit will contain all of the O-rings as well as the lubricants for a total rebuild. That should resolve your problem.
Dan
Posted on Nov 13, 2008
SOURCE: 20 Year Old Craftsman Lawn Tractor Steering Gear Slips
check top of sector gear mounting plate for waer this is the gear that hooks to you steering gear . the plate that it mounts to will ware down causing it to be loos and slip . the only way i know to fix it is to pull the cross member out and take it to a welding shop and have it built back up.if the bolt is as tight as itcan go .
Posted on May 06, 2009
backwoodsctr
  • 169 Answers
SOURCE: craftsman 316794990 leaf blower. I have a problem
Lakeviewpower dot com here is a link to my website. Call me on price and avilibility. Part number mc 9228 320602. Mtd model number 41ar322g799 1 972 475 9946
Posted on Nov 21, 2009
buffalonyman
  • 1865 Answers
SOURCE: take apart a motor assembly
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=315218050+&=part+number
How do I clear a jam?
Hi Gary:
SAFETY FIRST! Disconnect from air supply.
Pull trigger to make sure not "loaded"
- Here's what I would do.
1) Open magazine and remove stick of remaining nails
2) Try to remove jammed nail with pliers, pointy tool, etc.
3) Use allen wrenches to dis-mantle head until everything comes apart and jammed nail falls out.
4) re-assemble, cleaning and oiling at the same time.
Once done, re-connect to air supply and test.
Hint. A 2 inch nail can take some effort to penetrate, especially a knot in hardwood. Make sure you are using adequate pressure; that is the high end of the recommended pressure.
Cheers.
Dec 30, 2015 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
When I pull the trigger, the nailer just goes "futz". no brad coming out. no jam. not used over 100 psi. two nailers have given me the same problem
The first thing that comes to mind is they are not being oiled properly. Follow the directions for the number of drops of air tool oil to put in daily. If they have been run dry, this makes quick work of the Orings and requires rebuilding the nailer with new Orings.
The second thing is if contamination has gotten into the cylinder bottom thaat can happen if a jam has ever occured.
Dis-assemble the nailer and inspect for these conditions.
Jun 11, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
My brad nailer shoots staples without any problem but it jams on the second brad after being freed up from the previous jam. How to I rectify this problem. It is a fairly new stapler/nailer and has done...
Shoots staples fine but brads jam or bend. Check that the part called "guide bar", #35 on the parts diagram isn't getting stuck in the channel of part #30.
The guide bar retracts into the channel when driving a staple and springs out of the channel to guide brads.
The guide bar can get stuck in the channel if it's bent or gummed up. (Bent is likely the result of driving a brad into an obstruction.)
Mar 26, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Im65 wont fire! FAN RUNS WHEN ITS PRESSED DOWN AND ALSO WHEN TRIGGER IS PRESSED! PLEASE HELP
Sounds like you have a jammed nail...free the jam and push the plunger back and you should be good to go!
Feb 08, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
Driver cover "a" won't close
you may need to check if the driver blade is all the way up.first make sure you have the magizine open when you try to close the front latch.
May 21, 2009 | Porter Cable Cable BN125A Factory -...
My mastercraft electric brad nailer stapler wont shoot out nails?
Look for a jam in the gun.Sounds like a brad is "hung up" in it, probably right at point where it feeds into the mouth of the firing point. Be sure you unplug it before you do this.
Apr 24, 2009 | Air Tools & Compressors
Senco staple fastener not firing.
Make sure you actually removed the entire broken staple and there's not a piece still wedged up in there somehow.
Try raising the air pressure up to 125 psi and plug it in and unplug it a few times. Sometimes the piston can get jammed, and a smack with the palm of your hand on the side of the cylinder will jar it loose. If that doesn't work, try pulling the trigger as you jam the nose of the gun against a soft piece of 2x4 or something, repeatedly firing and jarring the tool. If this doesn't do it, you may have to open it up to clear the jam and put it back together.
Mar 28, 2009 | Senco Fastening Systems 760102N Pro 25 Xp...
Nailer jams with 1-5/8 brads
It sound to me that the 1 5/8 brads are not 18 guage but probably 16 guage and they will not work. Double check them first before going any further. You can usually lay them next to the smaller ones that work and see the size difference, if not let me know and I will dig deeper.
Feb 21, 2009 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Stapler works intermittantly
If not the power source or cord, the next activation point would be the trigger. Does the stapler make any sort of noise when the trigger is depressed? What type and model stapler is it?
Nov 02, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Craftsman StaplerBrad Nailer All Purpose EasyFire Forward Action Logo
391 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
