Question about Canon imageRUNNER 400 Printer
My canon ir330-400pcl error E677 HOW TOFORMATE PRIENTER BOARD
5 Suggested Answers
  • 11 Answers
SOURCE: CANON IR 400 COPIER - ERROR - E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Posted on Sep 18, 2008
  • 489 Answers
SOURCE: eror E677
roblem :
The machine displays an E674 code. This may be followed by an E677 code when the Fax pcb is removed. The imageRunner also has a Print Board installed.
Solution :
With the Fax Board and Print Board installed an E674 code occurred. When the Fax Board was removed an E677 code then occurred.
Try removing the PDL Interface pcb for the Print Board from the copier. Reinstall the Fax Board, if the E674 code does not occur and the copier is capable of sending and receiving faxes, then replace the PDL Interface pcb because it may be faulty and causing the two E codes; E674 for faxing and E677 for printing.
Posted on Jun 01, 2009
SOURCE: E677 Error in canon IR400
switch main power off and on E677
Posted on Jul 16, 2009
SOURCE: my canon ir 330-400pcl eror
My canon ir 330-400pcl eror E677 how to..
Posted on May 26, 2011
I have a problem in canon ir5000s e677 please tell me about e677
an error has occurred in the communication between the various printer board (accesories) and the main controller PCB
Jul 30, 2010 | Canon Office Equipment & Supplies
Como solucionar el error e677
E677 IS PDL board mounting error
Mar 05, 2010 | Canon imageRUNNER 400S Copier
What the codes means
Hello sir; The error code E677 it means " problem in communication between printer board and image processor board" , my suggestion is check all the conector between these two boards.
Sep 23, 2009 | Canon ImageRUNNER 330s Copier
Eror E677
roblem :
Solution :
Jun 01, 2009 | Canon imageRUNNER 400S Copier
Feb 24, 2009 | Canon imageRUNNER 400S Copier
Ir400 e677 error
E677 on iR400 is the otional printer board assembly was trouble. It must be change. Try this : replace your optional printer board assembly, the problem was correct? The other day you must bought optional printer board assembly. God Bless You....?!
Feb 06, 2009 | Canon imageRUNNER 400S Copier
E677
press the additional * 2+8 additional *
select the copier on the screen
select function
select clear
select ERR
press OK
restart the Copier
Oct 02, 2008 | Canon imageRUNNER 400S Copier
Sep 11, 2008 | Canon imageRUNNER 400S Copier
I have a Canon IR 330 with an error: E677 then it says to power off and power on which I have done to no avail. The error has a little wrench besides it
Error E677 is a problem with the connection between the printer board and the main board of the copier. Most likely the problem is a bad printer board, assuming no one has opened the back cover of the copier and the unit was working recently.
Jul 01, 2008 | Office Equipment & Supplies
Canon imageRUNNER 400 Printer Logo
122 people viewed this question
old marine
old marine
