Question about Sceptre Televison & Video
I have looked at both the scepter manuel and the magnavox dvd/vcr manuel and I cannot get the dvds to play. I've tried every way to hook it up?
sandrew
  • 2961 Answers
SOURCE: HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Posted on Feb 08, 2007
SOURCE: recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
Posted on Sep 03, 2008
MNfisherman
  • 11896 Answers
SOURCE: hooking a magnavox dvd/vcr to a analog tv
You will need to get new cables.
Posted on May 04, 2009
  • 108 Answers
SOURCE: I can't get the JVC system hooked up with my DirecTV Satellite system where I can use it with my TV and VCR/DVD I tried everything in the manuel please help thank you
You need to plug all the audio "out" of the individual units to the audio "in" on the theater system and change the function/unit switch to the unit you want to listen to. If hooked up this way the theateer system has to be on to get any sound no sound will come from the tv. The easiest way is connect everything to the tv, and if the tv has an audio output jack, plug that into one of the inputs on the theater system. Connected this way anything that comes out of the tv goes into the theater system and you can still get sound from the tv at all times.
Posted on May 27, 2009
  • 476 Answers
SOURCE: i lost the manual to the magnavox dvd/vcr dual
The easiest way to hook up the combo is to use the cable in and out to tv connectors located in the rear. for this connection you will hgave to set the TV to Channel 3 or 4. You can usually download an owners manual from magnavox.com, you will need a model number.
Posted on Mar 19, 2010
Magnavox mwc20t6
Toss this out as it is no good
Nov 22, 2013 | Televison & Video
My DVD and VCR in one has always played DVDs, and now when I tried to play a DVD, it says playback feature may not be available on this disc. I've played the same DVD on the same tv perfectly before!!
sometimes the discs get scratched enough that the player has difficulty reading them, using some car wax on the disc to clean it may help
Mar 09, 2013 | Televison & Video
How do i record from a vcr to a dvd
Concerning the Magnavox DV220MW9 VCR/DVD deck:
It can can only play DVDs, it can not record DVD them.
It can only record VHS tapes.
Jan 23, 2013 | Magnavox DV220MW9 DVD Player VCR
Getting message - "can't read" & "no disk"
sounds like the laser is out of synk with the encoders inside the player, to fis this you will need to disconnect everything from it, unscrew it and carefully move the lase all the way to the outside of its track, BE CAREFUL NOT TO TOUCH THE LENSE WITH YOUR FINGER, you may also wish to clean the lense while you are in there anyway. To do this dip a cotton swab in Isopropyl alcohol (the kind you use for cuts and scrapes), and roll the tip accross the lense of the laser, just let it air dry. Reassemble the player and it sould be good to go.
Jun 30, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't get video on vhs sound but no picture, is it broken
I had the same problem, so I took it back to basics. Hooked cable into VCR/DVD player and another cable from player to TV. S cable too, plus red/white audio. Plays DVDs on AV1 and VHS on Channel 3 on TV setting.
Jun 30, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Won't play DVDs.
I put in a dvd and get the "disc error" message. This magnavox dvd player is less than a year old.
Jan 05, 2010 | Philips Magnavox DVD/VCR Dual Player
Dubbed DVDs will not play
You have to use the Magnavox dual to finalize the discs, and then they should be able to play on other players. I don't have a manual for that exact recorder, but in general you would go to the Settings Menu of the DVD player --> go to Disc Edit --> and then select Finalize - the exact pathway might be a bit different on that particular recorder. Once you have finalized one of your discs, try it on another DVD player and see if it works. Good luck!
-Tha Mp3 Doctor
Feb 15, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Finalizing DVDs of a previous burner
Neither will work. you will have to try a computer.
Oct 28, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Televison & Video Logo
22 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
