Question about Watches
I have a Bulova B187 Bardwell Mantel Chime clock. However, the chimes don't work right. They are one, two or three chimes off from what they should be doing. I tried removing and replacing batteries, and pushing the reset button, but still can't get the chimes to work right. Any suggestions?
  • 15 Answers
SOURCE: I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMIN
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Posted on May 10, 2010
  • 5 Answers
SOURCE: Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
Posted on Jun 05, 2010
  • 5 Answers
SOURCE: I have a Strausbourg chime mantel clock. It chime
each press of the red button will advance the chime count by one. Advance the chime count to match the face clock
  • 82 Answers
SOURCE: bulova mantel clock won't keep
Try CAREFULLY cleaning the mechanism with naphtha lighter fluid. Lighter fluid is high grade naphtha. Be careful not to allow it to run on to the face and electronics. It may damage the face with stain or remove any decals or cemented numerals. It may only take a small amount to clean the shaft bearings. The lighter fluid cleans and lubricates without leaving a film. If you can, while the fluid is on the gears, manually turn the clock forward 12 hours. That will rotate all the gears fully. Us the fluid sparingly!
Posted on Apr 14, 2011
  • 2501 Answers
SOURCE: I received the Bulova B1843
Your clock is an electric one so you should be able to turn the alarm off.
Look on the sides or the back for a switch.
There may also be a volume control knob.
If you are really desperate, find someone who is handy with a screw driver to take the back off and disconnect the chime! although I feel that this should not be needed for a well designed clock!
You have obviously looked around for controls but I hope this helps.
Posted on Jun 19, 2011
Bulova mantel clock won't keep time
Sounds like a broken escapement, definitely a job for a horrologist (watchmaker)
Sep 29, 2013 | Watches
I have a Bulova westminster chime battery operated clock that the chime is off. how do I reset it?
You may call Bulova customer service at 1-800-233-3350 they are usually open 9 until 4 eastern time. It may just be a setting or you may need the battery movement replaced. I hope this helps you!
Sep 18, 2011 | Bulova Watches
I have an Elgin Westminster chime quartz wall clock (with pendulum). It uses a C-cell battery. It will not work at all. Please help if you can, since it has sentimental value to me. Don't know if...
I'm afraid you have to visit clock repair shop, as without close inspection it is not possible to say what's wrong with your clock.
May 18, 2011 | Watches
Bulova mantel clock won't keep time. New batteries and will chime. It's about 25 years old at least.
Apr 14, 2011 | Bulova Watches
We have a Acctim barrery operated westminster chime wall clock and cannot get the clock to work, pendulum & chimes work but not the clock, is there a reset button,how do we get it working. it is 11yrs...
Press the red button at the back and go through all the hourly chimes until you get to the next chime due i.e. if its 3.15 whebn your doing this, only go through the chimes until 3 o'clock and no further. Then turn the hands clockwise ONLY never anticlockwide and she should be fine.
Nov 19, 2010 | Watches
Antique Forestville Mantle Clock
Middle Key hole for the time.
Left side is for Chime
Right side is for the strike.
r/
David
Aug 25, 2009 | Seiko Chiming Pendulum Tambour Mantel...
I have a Bulova Mantel clock that is chimming off the hour how do I reset it?
I have a B1987 bulova baradwell mantel clock that is chiming off I can't find my instructions book. please help me to fix this problem thanks
Aug 02, 2009 | Bulova Watches
Elgin grandfather clock chimes not working
I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
Mar 29, 2009 | Elgin 0518709FA
Timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Oct 04, 2008 | Watches
Watches Logo
77 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
