Just bought from tigee direct ur pny ddr2 pc2-4200 533mhz/400mhz--problem is after installion my compu hangs --upgraded fro 52 to 2gb 2x1gb---compu is an elitegroup--pro4m800pro-m----wondeering if you could help tx
  • 1,800 Answers
The ddr2 that u bought its not in the same frequency that ur motherboard ram sockets got
get the same ram that ur computer had and see
or u maybe reach the maximum ram ability of ur pc
Posted on Aug 16, 2008
I have a dell vostro 200. I bought a PNY 2GB 2x1GB DDR2 optima memory kit. Is this the right choice and how do i find directions to install it?
Hello lshhiggins,
this is a "Direct Link" to {Download a PDF Manual].
It has "all the instuctions" needed to install the "Memory Module."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Click here: http://support.dell.com/support/edocs/systems/vos200/en/slim_tower/om_en/pdf/PK009A01.pdf
Feb 26, 2011 | Dell Computers & Internet
BIOS only seeing half of just-installed 2x1GB DDR2 RAM
did u check the old RAM...do they also show only half ?
may be ur new RAMs are not compatible with ur MB
what's the speed of ur new RAMs....400 or 533 ?
Jan 05, 2010 | PC Chips P23G Motherboard
Replaced a 512mb memory for the pny 2x1GB ddr2 pc2-5300
no just make sure there both in good condition one could be burned out like you could try using your 512 and a 1 gb or a 256 and see if that helps
Jul 27, 2009 | Computers & Internet
I replaced a 512mb memory for the pny 2x1GB ddr2 pc2-5300 to improve my system performance but when i turn it on my system shut down a while after i had log in to my account then i removed the memory card...
You may have a bad memory stick. If the two are not exactly the same spec they may not be compatible.
Haev you checked that your motherboard is capable of handling 2gb of memory? And that it is the correct type of memory(size and speed) and that you are placing it in the correct slots(ddr2 only goes in ddr2 slots and ddr only works in ddr)
The power supply makes no real difference to memory, replacing that is not a solution
Jul 26, 2009 | PNY Optima 2-Pack 1GB PC2-5300 DDR2 DIMM...
Upgrade Ram
No it wont take 800MHz RAM...
Using the DDR2 slots u can have 400MHz sticks (rare stuff), or 533MHz sticks
Using the DDR1 slots u can have 333MHz or 400MHz
Let me know...
Matt
Jan 20, 2009 | EliteGroup 945GZT-M (V1.0) Motherboard
Machine randomly restarts after upgrading RAM
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Dec 30, 2008 | Intel D102GGC2 Motherboard
MEMORY UPGRADE FROM DDR 256Mb to DDR2 1GB hangs when Log on/Booting
Its a memory problem obviously. Try dusting the memory slot and try inserting the memory into the slot a couple of times. If still not working, the memory may be incompatible(rarely, there are brands of boards that doesn't suit to certain brands of memory), or it may be damaged.
Sep 27, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
PNY memory
Hi
Dell Dimension 5150 supports DDR2 400MHz (PC2-3200) and DDR2 533MHz (PC2-4300) unbuffered SDRAM Memory (DIMM). You may install a total of four DIMMs in capacities of 256MB, 512MB, or 1GB. The maximum memory supported is 4GB.
From your query, I think the obvious question is; What is specification of the PNY DIMM and/or does the PNY DIMM meet the requirements for Dimension 5150?
Check for memory configuration and installation procedures for Dimension 5150 - http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1364711
The Chipset used on Dimension 5150 is Intel 945G Express. I am not aware of specific compatibility issues regarding the Intel 945G and PNY Memory modules. However, there may really be known issues that I am not aware of.
To proceed, ensure that the PNY Memory is compatible with Dimension 5150. If not, install compatible (memory type, speed, capacity) DIMMs.
Let me know if further help is needed.
Mike
Jun 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Is pny ddr2 pc2-5300 2X1GB compatable with the DELL DIMENSION 1100?
Hello mrkennx6
I was unable to access pny's web site to use their memory configurator for your Dell Dimension 1100. I did, however, find information regarding the RAM supported in your computer on Dell's web site.
You can find downloads and information HERE on Dell's web site (for your Dell Dimension 1100).
HERE is the Owner Manual for your computer. Please, refer to page 55 for information regarding the type of memory your computer supports.
To summarize information taken from the manual:
Install (matched pair) memory modules in DIMM slots 3 & 4
The matched pair of memory DIMMs should be either [PC2700 (DDR 333MHz)] or [PC3200 (DDR 400MHz)] SDRAM.
If you install a single module, be sure to install it
to DIMM slot 3 (the connector closest to the processor).
(Do not install ECC memory modules)
Please, let us know if this response was helpful for you or, of course, if you have more questions, etc on this topic.
Thank you
BJ
Apr 04, 2008 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
