Question about Frigidaire 16.8 cu. ft. Upright Freezer PLFU1778ES Stainless Steel
Freezer didnot seem to be running. (I was working lots of hrs and just noticed this problem 24hrs ago) I lowered the thermostat all the way and it didnot turn on. Took off the back lower panel and rotated the timer switch and the unit started right away. I don't recall the position that the timer button was in before I rotated it. Will that need to be reset if everything else works or replace the timer ?
    Master:
  • 495 Answers
That's what timers do when bad, won't let the compressor run when stuck on defrost. Replace it.
Posted on Jul 24, 2017
22yooper
  • 828 Answers
SOURCE: Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Posted on Jun 10, 2008
  • 1122 Answers
SOURCE: Dead Upright Frigidaire Freezer
YOU MOST LIKELY HAVE A FREON LEAK AND RUNNING THE FREEZER WITHOUT FREON IN IT WILL KILL THE COMPRESSOR UNLESS YOU UNPLUG IT AND GET IT FIXED,THE COILS ON MOST FREEZERS ARE IN THE SIDE WALLS SO YOU DON'T HAVE TO CLEAN THEM LIKE ON YOUR FRIG.HOPE THIS HELPS-MIKE
Posted on Jun 16, 2008
  • 1462 Answers
SOURCE: freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Posted on Sep 07, 2008
  • 173 Answers
SOURCE: frigidaire upright freezer MFU20F3GW7 (model)runs
Clean cooling coils....throughly. Check door seals.
Posted on Jul 08, 2009
SOURCE: I bought a used Kenmore upright freezer, it's been running all the time.
I'm Not a pro, but the comments refer to a refrigerator. I don't think they read your problem from start to finish. I went to RSI in Phoenix, and I would say it is low on refrigerant. I hope it's 134a.
Good Luck
Over the years the freon sloowly leaks out, it might need only an ounce or two but it will fix it in my opinion. I have the same problem with mine.
Posted on Jul 29, 2009
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
My upright freezer runs more than it is off
general design requires compressor on off ratio to be total run time to be 18 hrs on per 24 hr day off time allows compressor to cool down averaged over the day cool air is required around the outer walls of the fridge to cool the condenser coil at the rear also
Oct 03, 2017 | Frigidaire Freezer Refrigeration White...
My freezer is running but not freezing
Thermostats are usually located in the machine, lower right side facing it but sometimes the left side. More than likely you have a freon leak and the machine is starting to act like a fridge then a freezer.
Jun 05, 2012 | Freezers
Hello, I Have a new freezer. It was installed 16
the freezer will not cycle off until the desired temperature is reached.
Feb 12, 2011 | GE FUF21SVR Upright Freezer
Greetings: I have a 4-5 yr old Whirlpool up-right
lucky to get five years out of any white good
time to do the math
replacement cost of failed components
verses
benefits of a new up-right Freezer
Feb 28, 2017 | Whirlpool Freezers
Just had a new upright Frigidaire freezer delivered two days ago. Plugged it in immediately. It did not get cold after several hours. Turned it off then back on. Unplugged it. Unplugged it for several...
Whenever you get a frig or freezer delivered it is best to wait at least 24hrs (some say 8 hrs) before you plug in. It maybe unknown to you if this was shipped to you in the laying down postion. If it was and you plugged in it will not work because laying down the oil migrated away from the compressor.
Other than that the freezer could have (possible chance but still possible) problems that are out of your control. If you brought it at a retail store you have at least 2 weeks to exchange. Do that a.s.a.p.
Dont bother trying to figure out just exchange!!!
hope this was helpful
Apr 04, 2010 | Frigidaire Freezer Refrigeration White...
Admiral upright freezer dripping water inside on top
Hello.
I can help. Once we notice anything different from before we start becoming more aware of small variations. Regarding things on the top shelf warmer than on the bottom, this is always true because, "warm air rises and cold air falls". If you want the top shelf colder turn the thermostat to the next colder setting, always a good idea in the Summer season anyway.
Even though your gasket looks good, a ten year old gasket is not as pliable as a new one resulting in the moisture problem you describe. I would begin by applying a thin coating of vaseline to the gasket once a week for a month. This little trick of the trade will often work. If it doesn't improve the situation do replace the gasket.
Jun 25, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I bought a used Kenmore upright freezer, it's been on for over 24 hrs, and it freezeswell, BUT won't turn off. Runs alllll the time. Any suggestions??
Did you transport it STANDING or LYING down?
If Standing 4 possibilities:
1. The thermostat is hosed (replace)I had one like this and just put it on a $6.00 24hr time to turn on for 1hr every 5 hrs. (New Thermostat was $40.00)
2. The heat exchange fins on the back are dirty(clean with broom and air/vacuum cleaner)
3. The Door seals arent sealing and cold air is falling out the bottom, pulling hot air in the top (rehang door or replace seal) Note: a piece of paper 2" by 8" should be hard to pull out all the way around when closed. Like a cash register reciept. Cleaning with armor-All and then thinly coating with Vaseline may help
4. The Freon is shot and needs a recharge. (Costs $40-100.00)
If transported Lying down, there is now air in the lines and it needs to stand OFF for 24hrs. You may have hosed the pump with the air/freon mix, but let it stand so the air can surface and retry
Mar 26, 2009 | Freezers
LEC Fridge Freezer
clean up your condenser it's gotta be dirty and check your thermostat put it on the coldest setting and check your freezer fan.
if t ain't running check to see if wired with defrost thermostat if it is suspect it defective.
Dec 17, 2007 | Freezers
Frigidaire 16.8 cu. ft. Upright Freezer PLFU1778ES Stainless Steel Logo
257 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
