The fuse inside the tv has poped so i changed it but the standby light is still no coming on
  • 998 Answers
You still have a problem with the power supply try to check the resistors and the regulator, sometimes when fuse blow up some of the resistor become open, then you should check also the regulator to be sure, if shorted.
Posted on May 26, 2011
ViewSonic N3250W will not turn on
Do you get a red standby light at all? If not, I'd look first for the standby transformer as being defective. There may also be a fuse right by the AC power cord. Look around inside and update this with your results. Post whether or not there is a standby. We'll need to go step by step on this one.
Dan
Jul 03, 2008 | ViewSonic N3250W Television
Toshiba 19BL502B wont switch on
On the main power board inside the TV there are fuses take a look at them and the transformer and capacitors for damage
Dec 15, 2013 | Hitachi 50V500 50 in. HD-Ready LCD...
Power light blinking red, keeps poping up what the tv can do on the screen ,can't control any funtions
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 06, 2013 | Samsung LNT4069F TV
My LG 32LD320 won't turn on. I have no standby light and have even tried changing the fuse. Help please!
If total dead best way is to follow the AC voltage from power cord inside the set to see where voltage is lost.
Also , were you having any problems having to turn set on several times to get it on?
Mar 20, 2012 | LG 32LD320 32 HDTVReady LCD TV
The headlights wont come on. I've changed the fuse. park light work but not the headlights. now car wont turn over at all. tried jumping it & poping it. radio comes on & the inside light is...
Hi, Those have a fuse in the positive battery cable located in the middle of the cable about the center of the firewall on its route to the starter. I would check that fuse before proceeding. Also, those cables are known to go bad, My daughter had a 2000 cougar that kept draing the battery and lights wouldnt work right sometimes. Eventually it fried the alternator. After replacing the alternator and battery cable, it worked fine. Try the fuse first, If it is blown, I would recommend replacing the cable to cure the headlight problem. Mike
Jun 18, 2011 | 1999 Mercury Cougar
My tv one day just made a poping sound and now no picture shows up or sound..what should i do
Please check if the standby light (red light in the front) is functioning. If so then the safety fuse is blown off. This can be only repaired by a TV technician.
Mar 10, 2011 | Samsung Televison & Video
84 el camino, the running lights started poping fuses, 20 amps. After checking behind the light switch, found the harness had been hot over the years. Changed the harness, no changes; still no running...
MORE THAN LIKLY you burnt something like a fuse or a relay or possibily something in front or in back of the harness i know thats a lota help but different people have diff. solutions sometimes. CLOWNY DAGGERS
Nov 09, 2010 | 1987 Chevrolet El Camino
Screen blank
Sounds like a cap or fuse has blown in the set, you will need to take the back cover of and have a look, check on the power board for any blown caps, you will notice them straight away if one has poped, also check any fuses that may have blown they will also need to be replaced.
Feb 18, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
