Question about Hitachi Cameras
How do I charge it with my computer - Hitachi Cameras
  • 1,447 Answers
If you got a usb connector for camera to your computer, just connect it while your camera is off.
hope this helps
Posted on Aug 16, 2008
How long for battery recharging D610 ?
when the computer is turned off, the AC adapter charges a completely discharged battery to 80 percent in about 1 hour and to 100 percent in approximately 2 hours. Charge time is longer with the computer turned on. You can leave the battery in the computer for as long as you like. The battery's internal circuitry prevents the battery from overcharging. So About 2 to 3 hrs
When you connect the computer to an electrical outlet or install a battery while the computer is connected to an electrical outlet, the computer checks the battery charge and temperature. If necessary, the AC adapter then charges the battery and maintains the battery charge.
If the battery is hot from being used in your computer or being in a hot environment, the battery may not charge when you connect the computer to an electrical outlet.
Jun 06, 2014 | Dell Latitude D610 Notebook
Battery exhausted message no battery charged
The manual says:
Confirm all connections.
Off is selected for Charge by computer in the setup menu.
When charging by connecting the camera to a computer, battery charging stops when the camera is turned off.
When charging by connecting the camera to a computer, battery charging stops if the computer is suspended (sleeping), and the camera may turn off.
Depending upon computer specifications, settings, and status, it may be impossible to charge the battery inserted into the camera via computer connection.
So be sure you are charging the correct way. Best way to do is to remove the battery and put it on the charger for a couple of hours. If you have the battery out, you can check all connections of battery and in the camera.
In trouble shooting, more than a full page is dedicated only to the battery and the method of charging. The manual is still online, but should also on the CD you got with the camera.
Nov 16, 2013 | Nikon Coolpix 3200 Digital Camera
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
Nokia coolpix p100 wont charge
In General. Nikon Coolpix cameras TURN ON when you change them. This means when you plug in USB with a computer the camera turns on and the computer sees it.
If you turn the camera ON. And the Battery indicator shows "FULL CHARGE" you may NOT be able to charge it.
To eliminate variables. Do not charge with the computer until you charge with the adapter (wall charger). When the wall charger works then try the computer.
Look at page 145 in your manual for Computer charging.
Make sure your date and time are set in the camera.
Make sure it NEEDS a charge.
Aug 13, 2017 | Nikon COOLPIX P100 Digital Camera
Can u please tell me how to charge my mp3 player Laser 2G ? its new and they told me that it will be charged when i put it in my computer but i tried and i could not even while my computer is charging .
The MP3 player is charged using the supplied USB cable. When you connect the USB cable into the computer's USB port when the computer is switched on.
If the MP3 player still does not charge, try connecting it to a different computer. If it still does not charge then the USB cable may be faulty.
I suggest you take the MP3 player back to the supplier for a replacement. You should get them to test the MP3 charging.
Jan 09, 2011 | Laser MVP-2G (2 GB) MP3 Player
The Sansa charges via the USB cable. Fully charged, it should be good for 12-15 hours of playing. Be aware that not all computer USB ports put out enough current to charge external devices. If your computer doesn't charge the Sansa, try a different computer. You can also charge the Sansa using other USB charges, such as you'll see for charging cell phones from a wall outlet or a car cigarette lighter.
Jul 23, 2010 | SanDisk Sansa e250 MP3 Player
Computer not charging with universal adapter
hi i had the problem before , you have to buy dell charger in order to charge your battery, universal charger doesnot work with this, the only way not to lose your power is to keep the charger connected, in this way the battery will not be charged but u will not lose the power. again you need dell charger the universal only gives power but doesnot charge.
Best Regards
Mar 23, 2009 | Televison & Video
How to charge the battery
if you turn the e100 on, make sure the computer registers that it is connected, and you should see somthing on the screen of the e100 that shows it is connected and charging. It should charge both on and off, and it will charge if the computer is in 'sleep' mode but will not charge if the computer is off
Jan 04, 2009 | iRiver E100 Digital Media Player
Unit will not turn on
Your battery is recharged when connected to your computer. Turn the player off and connect it to your computer via the USB cord. The computer must be turned on. Initial charge should be for 10 hours with subsequent charges 3 to 4 hours for a full charge. A quick charge of 1-1/2 hours will give you a 70 percent charge. A fully charged battery will last up to 15 hours under normal use.
Dec 09, 2008 | GPX MW3837 MP3 Player
Cameras Logo
20 people viewed this question
Top Hitachi Cameras Experts
Parshiv Luthra
Are you a Hitachi Camera Expert? Answer questions, earn points and help others
