Question about Home
My hottub has a Balboa VS series controller Part no 54358. We cleaned the tub and when the heater came on, it tripped the breaker. I reset and watched the code numbers on the display. They were 188-137-61-61-24-24-PR . The hot tub went through prime and then the heat light came on. It ran for 12 hours and only climbed 4 degrees. Heater is a 4.0kw 15in 2x2 m7. motor: ultimax mod1016194
3 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: Jaccuzi hot tub will not heat?
sounds like it maybe the heater again. Have you pulled it out and checked the ohms? it should be at least 10.5 ohms
it could be the thermostat or the pressure switch - if either of those are not working it will not heat either.
Posted on Feb 24, 2009
slingspade
  • 6 Answers
SOURCE: My new heater does not work on my hot tub.
Test across both terminals at the same time. If you are getting 230V, disconnect power and check the resistance across the terminals. For 4kW, you should get roughly 13 ohms. If not, the element is bad.
If you get 0 Volts across the terminals, the tub is not heating. ManyBalboa packs switch both leads to the same leg of power, so you can get 120V to ground from each terminal, but you get 0V from terminal to terminal.
The clincher here is that the "heater on" light is off. I would double-check the pressure switch. You should test it with the tub running in heat mode. Disconnect one of the flag terminal leads from the switch, THEN test for continuity across the terminals. If you get none, you have either low flow or a bad pressure switch. You can verify by jumping the two wires together and see if the "heat" light comes on. Again, check for flow. I would run any of these tests with the filter removed. The symptoms you describe are very commonly caused by a dirty filter causing low flow. Again, pressure switch test. A bad sensor would cause the "current temp" to read too high, and a hi-limit problem would cause the little "heater-on" light to flash. Unless that little light is just dead (I've never seen it go bad), everything you say points to the pressure switch (or a dirty filter).
Posted on Dec 13, 2009
What runs on the .3amp fuse?
look on inside cover of control unit it has a schematic
Jul 04, 2014 | Balboa Instruments Pool & Spa
Balboa vs510s not heating
questions first:
is the heat indicator lighted up on the topside panel?
Is is tripping the breaker shortly after you turn the breaker on?
Is the tub running but not heating?
Rod
www.uspartscenter.com
888-521-6183
Jan 31, 2013 | Balboa Instruments Pool & Spa
My hydropool spa is tripping the circuit breaker. I moved my hottub off the deck onto a concrete pad next to the deck last summer. No problems, then over the first winter I went out one day and the...
it sounds to me like your hot tub has bugs take the control panel apart and clean the bugs out of it. if you have ants in the area they will get into the controls and cause it to trip out. i had similar problem with apump until i found the ants
May 19, 2011 | Heating & Cooling
We have a 2004 Balboa series spa and the breaker keeps tripping what could cause this? Everything has been working fine.
Understand that this information is beingprovided as-is and without warranty or guarantee. As with all electricalcomponents and devices, all work should be performed by a licensed spa or pooltechnician. Serious injury or death can occur if a component is improperlyrepaired or installed.
There are several reasons the breaker can trip. It could bea bad pump, bad heater, GFCI or wiring issue.... Typically unplugging eachcomponent will help isolate which component is causing the trip. It is rare fora board to cause a breaker trip, so if all components (including both legs ofthe heater) are disconnected and the breaker continues to trip then you move onto wiring or the GFCI.
You can find answers to common spa or bath problems online at http://www.balboadirect.com/support.aspx
Apr 02, 2011 | Balboa Instruments Duplex Digital Panel 2...
My hot tub still trips the breaker,and i replaced
Check the heater. The heater is the most likely cause of tripping electric.
If you're not sure what you're doing, please contact someone who does. Electricity isn't something that should be played around with especially when in close proximity to water.
Regards,
Ian.
http://hottub.synthasite.com
May 12, 2010 | Balboa Instruments Duplex Digital Panel 2...
I have a Sundance Spa that has started tripping the breaker
It is unlikely the Breaker is BAD, that just doesn't happen. To trip a breaker there MUST be an Overload, or a Short circuit, that's it. You will have to use a meter an troubleshoot the system. Something is very wrong..please use the links below to troubleshoot and repair. Please Be careful. http://spababes.com/heaterhelp.html
http://www.spadepot.com/spacyclopedia/spa-heater-element.htm
http://www.poolandspa.com/page596.htm
May 07, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
The hottub keeps kicking the circuit breaker off.
Either the breaker is bad or you have an electrical problem. Unless you know how to work with electrical problems call for service. If you unplug the hot tub and plug a lamp or hair dryer into the outlet does the breaker trip? If yes, call an electrician. If the outlet is fine call for service on the hot tub.
May 01, 2010 | Home
I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
Regards,
Ian.
Jun 07, 2009 | Balboa Instruments Duplex Digital Panel 2...
Home Logo
294 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
