Bus ovp fail shutdown - Computers & Internet
How turn off no bus in my pt cruiser 2001
Hello, it means that the instrument cluster is not seeing messages from the PCI bus, which is how it communicates with the other modules on the vehicle, if you're not having any other problems it's unlikely that the communication bus has failed. You most likely have either a broken bus wire going to the instrument cluster or a failed instrument cluster itself. If you are having other related problems you're either going to have a failed module corrupting the communications bus, or a grounded or shorted bus wire, which will also cause the bus to fail. These are probably the hardest to diagnose problems we see on these vehicles.
The first thing you'd need to do is using a DRB3 scan tool do a module scan to determine if the pci bus is operational. If it is you can then focus on the instrument cluster. If it's not you'll then need to check for shorts to ground and voltage on the pci bus wire, if either is present you'll need to find the cause of the fault.
006 Chrysler PCI Communications
May 28, 2017 | Cars & Trucks
What does the letters OVP mean as they keep appearing on the screen of my Samsung flip phone whenever I attempt to charge battery? Also do I rectify this problem?
OVP stands for Over Voltage Protection. OVP protects the battery and system against faulty input. You may want to change the charger.
Jun 12, 2014 | Motorola Mobility RAZR V3
Ups indicating shutdown due to 016 dc bus low
Could you tell me what kind of UPS (brand/model) you have? DC BUS low is most likely caused due to DC-DC converter error or BUS error. If you can send me the brand and model I will look in to it.
Dec 18, 2012 | Computers & Internet
Charge being paused by ovp
I just had this same problem, I just shut it down and restarted it and now it works!!
Aug 14, 2012 | Samsung Cell Phones
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
WHAT SHOULD I DO IF IT DISPLAY DC BUS LOW SHUTDOWN
The problem comming from Prag board and zogh board. replace both card to solve the problem.
Jun 14, 2010 | MGE UPS Pulsar Evolution 2200 UPS System
6 bliks on sony kp-46wt510
KP46WT510 Shutdown 6 Blinks. 6 Blinks = Low B+ OCP/OVP
SOLUTION: Replaced Flyback transformer. It had no rings on the ringer test.
HQ
Comments: Any load on the B+ line can cause 6 Blinks.
Example: If the 200v line is loaded down will cause a drop in B+ due to bright picture current demand.
Click Here! to download the Sony Kp-46wt510 full service manual.
Nov 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Computers & Internet Logo
347 people viewed this question
David Payne
David Payne
