Question about Jensen 100W x 4 Amplifier KA5 Car Audio Amplifier
Car stereo my car stereo turns off when i push my break pedal any sug. on what the problem is???????
    New Friend:
    Problem Solver:
  • 4 Answers
You have a bad ground try to reinforce the ground or try scrapping a little bit of the paint off so you can get a good ground.
Posted on Aug 16, 2008
I have a 2011 nissian altima and when i push on break the break light goes off but when i let off break light comes on what does it mean?
check your brake light switch on the brake pedal, more than likely thats where the problem is, when pedal is push down, the plunger on the switch is released to turn lights on, when you let up off the pedal the plunger gets push in by the pedal to wich its mounted, which inturn shuts the lights off. do you see how its suppost to work ? thats the only switch for your brakes , soooo yours is backwards correct ? must need re-mounted in its proper location........... OK
Mar 01, 2013 | 2011 Nissan Altima 2.5
What causes the break light swich to push, ive took apart the swich and can push it and break lights worked but when i put swich back on with clip it dose not work when i hit the break peddel
nothing, It doesn't work like that, when your brake switch is mounted , correctly , your pedal has a bracket on it that pushes the switch plunger in so brake lights are off. when you push brake pedal in, to stop vehicle, the switch plunger (spring loaded) comes out to turn brake lights ON ! get it ? when you release pedal it pushes plunger in, to turn lights OFF !
Jan 15, 2013 | 1997 GMC Sierra
2001 maxima break lights remain on when off
There is a break light on off switch which is connected to the break pedal as you push the pedal the break light is on and when you release the pedal light goes off just look along side the pedal upwards there is a small connector swich just check the small pin type switch as it is in the refrigerator doors try by pushing it in gently to check if it is jammed or the other reason could be that the break pedal remains slight pushed inside from its orignal position to keep the switch on for this check the pedal springs amd lubricate them
Aug 16, 2012 | 2001 Nissan Maxima
Please help.I have a 2005 Dodge Caravan.When I start the van the rear break lights would turned on automatically.When I step on the break the lights stays the same,no indication of breaking from the rear...
You have a bad break switch. It is located under your dash, above your break pedal. The stem of your break pedal, when pushed down, activates the break switch. When you push, the break light comes on. It is chrome looking. It is a round cylinder. That should fix you up. If you need anything else, please let me know. Thank you for choosing FixYa.
Feb 15, 2011 | 2005 Dodge Caravan
My brake lights don't work. I've changed the bulbs & checked the fuse. any ideas?
You could check the brakelight switch located on the brake pedal linkage. Sometimes they move out of adjustment, sometimes they fail. The ones I've seen are usually plastic and the threads strip off so the jamb nut won't hold the switch in place correctly. It should be round (or at least the part with the mounting nut should be round) with a plug with 2 or 3 wires going into the back and located so that the brake pedal lever moves away from the switch when you push on the pedal. If you deem that it needs to be replaced the switch should be available at most auto parts stores.
Feb 11, 2011 | 2003 Chevrolet Tracker
2002 Taurus - brake lights won't turn off when car is shut off.
Usually this is caused by a broken or faulty brake switch. They are usually located above the brake pedal, inside the car. Look at the pedal from inside the car. Push the pedal down and watch it. Look for a switch that should extend a plunger when the pedal is pushed down. The plunger is supposed to go back into the switch when the pedal returns to it's normal position. This is what lets the brake lights know the pedal has been depressed. In most of the cases I have seen the plunger breaks or it gets cocked sideways and stays out or the switch holder itself breaks and the switch moves instead of the plunger. Then the brake lights think that the pedal is being pushed down even when it's not. Start there.
The only other time I have seen this is when someone used the wrong type of light bulbs in the brake lights.
Feb 23, 2010 | 1998 Ford Explorer
Brake lights always on.......
sounds like the brake light switch is stuck the switch is on the brake pedal when you push the pedal to apply brakes it completes a normally open circuit
Apr 15, 2009 | 1998 Mitsubishi Eclipse
2006 HHR trailer wiring?
Check ground wire to the trailer. On the vehicle and the trailer. Make sure you have a good ground as lighting will seek any path for ground which will feedback and cause lights to act really weird.
Mar 21, 2009 | 2006 Chevrolet HHR
Problem wtih starting car
I had the same issue. It turned out that the break pedal switch was broken. The engine start push button is connected to a second break pedal switch that senses when you push it. That switch is independent from your main break pedal switch that turns on the brake lights of the car.
Jul 17, 2008 | 2007 Nissan Altima 3.5 Sedan
Jensen 100W x 4 Amplifier KA5 Car Audio Amplifier Logo
234 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
