Question about Bosch SHU3305 Dishwasher
BOSCH SGS46M78AU Help. How do I remove the top to my machine so that I can get it under my existing work top.. I can't seem to figure out how to remove.
  • Anonymous Mar 23, 2014
    Can I remove the top of the machine so it can go under the bench
  • 88 Answers
Its like your cabnit draw
lift litle up when that all is up
Posted on Aug 16, 2008
Need repair manual for bosch sgs46m78au/86
Check the line in from the faucet to the washer. Two hoses, Cold and Hot. Either one (you did not say which) turn off the faucets, remove the hoses, and blow hard to see that nothing is trapped inside. If clear, replace, turn on the water again, and run a test. If one side fails, it could be the solenoid that needs to open and close when there is a demand for water. The valve that must open and close is controlled by the circuit board in the panel. If the Board is Defective, you cannot turn on the valve solenoid and it may have been stuck in the Off Position and never opened again. Go to Bosch on line and seek further assistance from the technical department. You may however; obtain a FREE Manual in PDF form on line.
Dec 19, 2013 | Washing Machines
I can't figure out how to reverse the door on my
You need a left sided hinge kit...here is the link to the part from Bosch http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodlg.htm?Maktx=wtz1260&eshoptype=A
There is a PDF on their site under "support" and your model number wtmc3321us that shows this on page 8. Hope this helps you! :)
Jun 11, 2012 | Dryers
How do I change the waste hose on a Bosch Dishwasher Model Number SMS53E12GB the existing hose has been crushed by the base of the machine. I cannot see how I can get to the connection point at the base of...
It is not the easiest thing to do,here is what you have to do;
turn off power supply and water to the dishwasher
remove screws mounting d/w to counter top
remove lower panel
disconnect water and power from d/w
lower legs
pull out from under counter
remove panels covering door hinges
remove linkage from door spring to door hinge
remove the Torx screw securing tub to base frame in the front&rear
pull on base frame to seperate tub from frame about 8-10 inches
remove drain hose from drain pump/install new hose
reassamble in reverse order
Good luck,
Gene
Aug 06, 2011 | Bosch Dishwashers
I began a wash on a Bosch WOL2200 top loading machine and it began to make scraping noises as the drum turned. I opened the door once it was done and now i cannot get my clothes out! The drum wont turn by...
Sorry to read about your problem, I hope this helps you out.
the cover's will have to be removed, if you cannot figure this out or a friend, you will have to call a service company
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Bosch WOL 2200 Top Load Washer
Dryer turns no heat, where is red reset button? do you have to remove the entire back of the machine?
Have a Nexxt 3300 and believe yours is about the same so yes, several screws to remove from the back. Top also has to come off because two screws to the back are under the top. And for the top to come off the control panel has to be pulled away. Only four screws under four white caps to remove for panel to be loosened. The top is attached with two screws in the back and four nylon clips under the top. The red reset button will be easy to see after removing the back. It is attached to the heating element housing. It is not hard to do, just a pain to get to the reset button. Link to Bosch appliance website with give you a diagram to help. http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTMC632SUS%2f02&ESHOPTYPE=A Good luck.
Dec 05, 2010 | Bosch WTMC632SUS Platinum Series Nexxt...
How to remove latch from Bosch SHU3306 dishwasher dispenser?
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Jul 22, 2010 | Bosch SHU3306UC Built-in Dishwasher
Need to replace rusted top on washer. Have top, just can't figure out how to get to the screws holding it on. Have schematic. Will transfer existing lid and switch to new top. Thanks
some have 2 or 3 screws on back when released push lid forward or backwards, others are more tricky the front panel has to be removed this can be snap connectors or hidden screws under the panel .
May 12, 2009 | Washing Machines
Bosch dishwasher model shv4800/shi6800/shu6800
you should have two filters. one you can unscrew .its a smaller round looking filter right under the bottom spray arm .once removed you just pull up on the flat filter that lying on top of the sump area
Dec 22, 2008 | Bosch 23 in. SHU303 Built-in Dishwasher
BOSCH WASHING MACHINE RETAINING SPRING FOR FRONT DOOR GASKET
it is very hard to get the ring on front load washers,
it is much easier to remove the top. bottom and the front control panel
then the door and support panel.
now you have access.
some times you have to remove the counter weight in some models before putting on the ring.
if you can do it without removing these items you are very very good.
May 01, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch Dishwasher
the circut board is very costly stay away from that one
Mar 28, 2008 | Dishwashers
Bosch SHU3305 Dishwasher Logo
737 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
