I HAVE A MAGNAVOX H2080MWS HDD DVD RECORDER;THE PROBLEM I HAVE IS THAT THE DVD RECORDER DOES NOT RECORD ON DVD DISC IT COMES UP WITH ERROR,EVEN AFTER I'VE CLEANED THE DISC AND THE RECORDER. JOE MARTINEZ
  • 3 Answers
SOURCE: DVD Burning doesn't work..no Disc in Setup..
Been checking out my m/c and found that there are many -r & -rw discs the m/c does not recognise which gives rise to this problem. However the m/c does recognise VERBATIM discs and I have been able to record and dub to them with no problems.
Posted on Mar 11, 2008
  • 3 Answers
SOURCE: disc will not finalize error
You don't need to delete timer rec programs to Finalize, Format or Erase discs!
Set the Mag 2160A (mfgd in 2009) to Source L3 (DV) using the Source button on the remote.
To Format a RW disc, set unit on L3 BEFORE inserting a new disc cuz the Formatting op is automatic and starts right away. It's also so short on a +RW (longer on a -RW) that you could think it had been Formatted.
Finalizing requires you to select it from the Disc Edit menu, so you can set the unit on L3 after inserting a disc for this op.
More into on all aspects of setup and op are here:
http://www.avsforum.com/avs-vb/showthread.php?t=940657
Posted on Dec 17, 2009
Testimonial: "it worked! i have had this unit for almost a year and love everything about it except that it would not finalize the disc. thanks!"
SOURCE: LG HDD DVD recorder RH7521W is not able to read
Mine had a similar problem. I assumed there might be some dust on the laser. I used an air compressor and pointed it at the DVD slot as it was opening and closing to blow some air around inside the unit (and hopefully dislodge any dust). It worked. The discs that would not play before did play after. I didn't have the air compressor nozzle too close to the opening as I didn't want to dislodge anything I wasn't supposed to. If it was dust on the laser, you might be able to clean it in other ways, such as removing the cover and using a cotton tip (take power off first!). That would have been my approach if I didn't have an air compressor.
Posted on Feb 02, 2010
SOURCE: DMR-EX98 CANNOT USE DVD RECORD FUNCTION
This problem has just happened on my dmr-ex98 although perhaps more extreme in that the dvd drive will not read any disc let alone record - makes an attempt to read disc plus phantom disc but gives up. hdd.vcr also ok. Any guidance?
Posted on Feb 28, 2010
SOURCE: I have a SV2000 Vhs/Dvd Recorder. I can't seem to
Do I have to download something to be able to record vhs to dvd on my sv2000 dvd/vhs recorder?
Posted on Sep 12, 2010
I have a Magnavox MRV700VR. I can record on a DVDR, but when I try to record on a DVDRW it tells me "disc error". Why?
It will be either that you have not formatted the disc or that you are using the wrong type of disc. You will need a DVD+RW on a + machine or DVD-RW on a - machine. Most recorders will playback the other type but not record on it.
Jan 28, 2013 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have...
I have a phillips magnavox Problem with the Philips Magnavox MWR20V6 DVD Recorder / VCR Combo I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have cleaned the lens with a disc cleaner and still didnt help,same thing is happening. i am also using the same type of disc that I have been since day 1. Can you help??
Mar 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording Error E 4 54043e02 "Can Not Record On This Disc"
I was getting the "can not record to this disc" error on the Magavox DVD Recorder and a Memorex lens cleaner solved the problem.
Sep 16, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I bought a Magnavox 810H 160GB HDD/DVD recorder. It's a decent machine which worked perfectly for a few months, but now I can't get it to record to DVD. The HDD recording and playback functions work fine,...
Try switching it over to DVD . Because you may still have it on HDD when you put the disc in it may be that the unit is still thinking you are on HDD and don't recognise it as a disc just the hard drive
Sep 11, 2008 | Televison & Video
Recording error
mine was doing the same thing.and we found out that if you recorded something and dont finalize it will not recored anything else till you finalize what you recored then it works again
Jul 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
66 people viewed this question
 Grubhead
Grubhead
