Question about Coleman Heating & Cooling
A guy came last winter when we had no heat and changed some wires for us to get heat, now the ax doesn't work, only heat blows out even in cool mode at very low settingse
  • Christopher Grant May 29, 2011
    This system is NOT a gas furnace. This is a Coleman heatpump on a mobilehome. I feel as though the auxiliary or emergency heat coil may have been straight wired, but I don't know the original wiring pattern/diagram. What would be helpful is a pictorial or wiring diagram that specifically shows the components and how they should be wired for correct operation.
    This system is not gas fired. It is an electric Coleman heatpump, with electric heat coils for auxiliary make-up/emergency heat. I need a pictorial/wiring diagram that shows me exactly how all of the wiring should be.
    Genius:
  • 1,015 Answers
The first thing I would do is to make sure that you have power to your outside unit. The main power coming in should be 220-240. The power in should go directly into the contactor which shoul have two lines from the thermostat to bring 24 volts in to engage contactor.Without knowing what has already been done it's possible that he took power from the transformer on condensor to power gas valve to get you heat. If this is the case then you will need to get 24 volts back to contactor to make your a/c work.Hope this helps you some. Thank you.
Posted on May 26, 2011
Mitsubishi
I've read and heard from local techs that the Mitsubishi (along with lots of other mini split brands), are known for the indoor coil leaking freon. Even after a fee years of working great! Have them serviced. They are probably low on refrigerant. Try checking the trouble codes on the remote.
Aug 26, 2017 | Heating & Cooling
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
I have a 1998 Oldsmobile Bravada with automatic climate control that blows cold air in the winter and hot in the summer. The thermostat is working fine and it doesn't need flushed. There are no le
It sounds like the system is fried. Based on the description, it is just pulling in the outside air and not doing anything to heat or cool the flow. Unfortunately, this is a job for your preferred mechanic.
Oct 28, 2012 | 1998 Oldsmobile Bravada
My refrigerator model tbx22rg works great at winter but at summer doesn't work at all, Why?
Its not even a refrigerator you dumb egyptian ****.. SOME ONE SOLD YOU A REFIGERATOR BOX~!!!
Aug 04, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
We get a horrible smell occasionally with our Rinnai Avenger 25 nat.gas heater when alight. The filters are clean & was serivced last winter. It was making the smell at times even after the service. It...
From what you have described, it sounds like a case of delayed ignition or as the Owner's Manual calls it a "Combustion Control Fault"or "Incomplete Combustion". This can be caused by several things: A change in the gas pressure; dirty or clogged burner, electronic fault in the combustion controls.
Despite having it cleaned an services last Winter, 12 months have elapsed, with the unit just sitting and collecting dust and spiders. Portable Heating units should be serviced annually. Usually in the early Fall, before firing it up for the heating season.
Hope this helped you ... Cheers.
Jul 06, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
We do not run our a/c unit during the day so in the evening I turn it on and it seems like it takes forever for the inside of the house to cool down. This is an older model carrier and was in the home when...
Take a look at the condensor outside. With the unit running even on a cool day, the condensor fan (outside) should be blowing hot air. The air temp coming out of the register should be 20 degrees cooler yhan the coils in the house.. This is a reverse way to chk the evaporator temp for proper cooling. Now, the wire could be a problem if it is coming from the thermostat. Take notice of the outside unit is being controlled by the thermostat by having someone go from off to cool on the T-stst. If everything is working but the discharge air is warm your unit may need a charge. If I haven't confused both of us, I'll watch for you reply -Ned
Jul 06, 2011 | Heating & Cooling
I have a ''GE"heat &
Look at the wires that go to the compressor and make sure they are not burned off. Inspect the capacitor tops for swelling and loose or burnt wiring. Also check the connections coming from the controls. May have a wiring problem or even a bad compressor. How old is the unit?
May 17, 2011 | GE AJCQ06LCB Air Conditioner
Reversing valve wire kills either heat or AC
Your solution is throw that Hunter tsat away and get a good one. You need one with 2 stage heat 1 stage cool heat pump tstat. Heat pump tsta has w,y,o,g,w,rnad w2. Don,t buy one without this one it. I have been in this business 45 years and people are always getting sold the wrong tstat at Lowe or Home Depot. Those guys dont know jack about Tstats. Keep in touch Rus GOOD LUCK. Get the right tstat follow the letter on wiring and you wont have any problem.
Nov 19, 2009 | Heating & Cooling
Heater issues.
did you mount the thermostat properly... sounds like it is reversed
here is a picture of the proper orientation
Jan 26, 2009 | 1989 Nissan Maxima
Heating & Cooling Logo
19 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
