Question about Dishwashers
Dishwasher is not cleaning the dishes, leaving a white residue on the bottom and front of the machine
    Guru:
  • 500 Answers
Hi fmitchell,
White residue is normally caused if you use a very high heat setting. Reduce the heat and things should improve.
Also remember to check the Salt container at the bottom of the machine, replace salt if necessary.
Kind Regards
Jacques
* If you found this solution helpful, please rate my answer
Posted on May 26, 2011
Dishes aren't clean, lots of white dried on stuff on top of glasses and dishes
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine once more before using it again.
Jun 29, 2011 | Dishwashers
Dishwasher leaves white film on dishes
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Apr 17, 2011 | KitchenAid Dishwashers
My dishwasher suddenly started having a white residue to cover the dishes. This white residue is also along the edges at the bottom of the door and bottom front of the interior of the disherwasher and...
Remove the bottom strainers plates and make sure that the outlet pipe the pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Mar 29, 2011 | GE Dishwashers
Ge Triton dishwasher GSD5500GOOWW was not cleaning like it used to- I cleaned screens at back bottom-very dirty- also-detergent cup stuck opne - took door apart and got it unstuck - it works fine now. - it...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 23, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
The dishwasher does not get my dishes clean. it leaves heavy residue on all that is in the washer. it worked fine but now it is not getting the dishes, silverware and glasses clean at all.
heatman101
Nov 29, 2010 | GE Nautilus 24" Built-in Dishwasher
Both dish drawers are leaving a chalky dried on residue on the dishes. I ran a cleaning detergent in both drawers, made sure salt in water softener was filled, checked filters, and they are still leaving...
heatman101
Oct 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dishwasher leaves a white residue on my dishes and just doesn't seem to be cleaning dishes right. it is also kind of loud.
heatman101
Oct 08, 2010 | GE Nautilus 24" Built-in Dishwasher
White residue left on dishes; Plastic ware being oxidized
heatman101
May 10, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Dishwasher leaving white sticky residue on dishes
maybe machine is not filling with correct amount of water try adding an extra omunt of water say 2 litres and see if the machine sounds like it is washing properly
open the door when operating and observe wah arm positions as these turn aroun as it washes
also check that the wash arms are not blocked
Nov 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
DISHWASHER MODEL # KUDS03FTBL2 WORKED VERY WELL UNTIL TWO TO THREE DAYS AGO DISHWASHER NOW LEAVES MASSIVE FILM AND DEBRIS (LOOKS LIKE FINELY GROUND UP GRAVEL AND DIRT) OTHER DISHES AND SILVERWARE HEAVILY...
There is a product out called the dishwasher filtration system. it filters the water going into your dishwasher reducing the hrad minerals that leave that white residue. it is very affordable and works amazing. it goes right under the sink and is easy to install. go to www.dishwasherfilter.com for more info on it.
May 01, 2009 | Dishwashers
Dishwashers Logo
74 people viewed this question
Top Dishwashers Experts
Owen Barnes
