Question about Vacuums
MAY I HAVE THE WIRING DIAGRAM FOR A 3 GANG SWITCH
Miele model SEB217-3 beater bar stooped working
Check the switch .It usually have a wiring diagram
Jan 25, 2018 | Miele Vacuums
My kirby g4 motor runs backwards and so the power drive when pushed forward wants to go backwards. I need the wiring diagram so I can get it wired correctly.
The wires to the switch, coming from the carbon brushes, have been reversed. The carbon brush closest to the switch goes on the lower switch terminal.
Dec 24, 2010 | Kirby Generation 3 Bagged Upright Vacuum
I nead a wirring diagram to fit a four connection power switch to a Kirby G4 cleaner
There isn't a wiring diagram for these. There is only a switch, a motor and a light, so a schematic isn't really required.
I'm assuming you've made the fatal mistake of removing the wiring from the old switch and have forgotten where to re-connect them. It's also not very helpful that all the wires are white, so I can't really tell you to connect red to "x", black to "y", etc.
The really important connections are the power cord and the motor brush connections. You can't get the power cord wrong as the plug is shaped to only allow connection at one orientation: I've drawn you a diagram to show 3 of the 4 connections:
As long as the motor brushes are correct, there wont be any problem. If these are the wrong way around, the motor will run in reverse and will blow instead of s/uck.
The headlight can be wired either way around so if these connections are switched, it shouldn't matter. You have a 50/50 chance of getting it back the same way as it was originally and if there is any problem with the light, you can easily switch these wires over.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 16, 2010 | Kirby G4 Bagged Upright Vacuum
Need wiring diagram for Rainbow D4C vacuum to install rocker switch
You can get a wiring diagram at http://www.rainvac.com/schematic.html
You can get all of the manuals, and the full breakdown schematics, of every model there.
If you need me to tell you which wires go where, exactly on the switch, let me know. I am a Rainbow vacuum expert and know everything about almost every model ever made.
If you have any more questions, let me know.
Thank you,
Feb 20, 2010 | Rainbow Technologies D4 Bagless Vacuum
Vacuum won't switch on;got it apart;cord ok;need wiring diagram
Its a great idea to write on paper how its connected . So it helps with dis assembly & reassembly . I tried a Internet search . Looks like it'd cost money for a service manual. Though. I found a Kirby Spares Website that could help. Although it doesnt have Document downloads with repair help. There are spares & there is a telephone number for an engineer available during office hours. That you could ask for repair help. With wiring connections for your Kirby G3.
http://kirby-owners-club-shop.com/faqs.htm
The Engineers Telephone Number is 0845 388 9301
I repaired my Parents Kirby Heritage some while ago. With a new set of Brushes. Bulb Repair.
They are a Great Machine. Bit Expensive. Though Tough & Well Made !
Gary
May 24, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Wiring diagram Oreck XL2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=650346
Posted by geohil on Jun 06, 2008
Can I get a wiring diagram of the handle on an Oreck XL 2.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. The best place to get an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 06, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Vacuums Logo
383 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
