OKI C700 printer making squeaky noise when printing?could it be the cartridge- changed few hours ago?Thanks
    Scholar:
  • 118 Answers
If the squeak only developed after changing the toner cartridge then I would say yes it could very well be the cartridge. Particularly if it is a generic brand.
I have found that most squeaks in printers are caused by the toner/drum cartridge
Posted on May 26, 2011
My hp 3500 is making a sqeaky noise before it prints. the page comes our beautifully but the noise is disturbing.
I have found these printers to be noisy at the best of times, but bad cartridges can add another level of noise to things. Squeaky cartridges are not uncommon, particularily if they are remanufactured cartridges and not orignal HP products.
May 04, 2011 | HP Color LaserJet 3500 Printer
My oki c3400 printer makes a really loud clicking noise when you first turn printer on and it cycles through, and it also does it when it cycles through printing. Any ideas what the problem could be?
My OKI C3300 was the same and an engineer found the Cyan drum was bouncing on its gears being very stiff to turn. We changed the drum but it was still the same. Changing the cartridge cured the problem, that was jamming the drum.
Mar 10, 2010 | OKI C3400n Laser Printer
Oki C5500 printer has ghosting on most of the prints. After making a number of copies, the ghosting is greatly diminished and the copies are OK but not great. Started a couple of weeks ago. I have refilled...
This type of print problem associated with laser printers is due to the corono wire needing to be changed. The wire is not fully pulling the toner off of the drum completely. If you can access it, cleaning it may help (usually a lever that you are supposed to run back and forth a few times that wipes the corona wire). If the cleaning doesn't help, then it probably needs replacing.
Feb 08, 2010 | OKI C5500n Printer
Faded lines of black across part off printed page
please you used the colour printer ? if yes then your check the csrtridge a refeling the towner and service the cartridge and service in printer and aply the print is ok.
Sep 22, 2009 | OKI C9300 Led Printer
Squeaky HP printer
Typically the squeaking comes from the toner cartridge. If you just purchased it, take it back, it's bad. If you can find an identical printer, swap cartridges and see if it makes a difference.
May 27, 2009 | HP LaserJet 1300 Printer
OKI C5400 & Vista
Assuming that you are using the same paper and have not changed any of the consumables you should do the following:
1. Clean LED head with lens cleaner or soft tissue.
  1. Remove the toner cartridge and give it a few shakes then reinstall it.
  2. The Toner Could be low so Change toner cartridge.
4. Make sure that the paper is not damp as this will cause fading and poor quality printing and images.
  1. The image drum may have been light contaminated so remove it from the printer and store it in a totally dark place for several hours then reinstall it.
  2. If the image drum is dirty then wipe it very gently with soft tissues, being careful not to scratch it.
  3. Open the top cover and check to be sure that each toner cartridge is fully seated and that each toner cartridge lock lever is pushed all the way back.
  4. Press the top cover release latch and open, then close, the cover.
  5. Check MEDIA MENUTRAY1 MEDIA TYPE and set as required. Do the same for TRAY2 and MPT.
  6. Check MEDIA MENUTRAY1 MEDIA WEIGHT and set as required. Do the same for TRAY2 and MPT.
  7. Possibly set the value of media weight in the menu to the next heaviest one.
  8. Check PRINT MENURESOLUTION setting and set to 600 x 1200DPI
  9. Check PRINT MENUTONER SAVE MODE and make sure this is OFF
  10. Check PRINT MENU – MONO PRINT SPEED and make sure this is set to MIXED SPEED
Aug 12, 2008 | OKI C5400 Laser Printer
OKI C5200 - Faded black print area
Trying cleaning the black LED's that are on the top portion of the open clamshell. Use rubbing alcohol on a rag and wipe each bar x4/. These units charge the drum surface where print is going. This should work.
Jun 12, 2008 | Samsung OKIDATA - OKI C5200n - Printer
OKI c5400
  11. Check the COLOUR MENU – DENSITY CONTROL and set this to AUTO
  12. Check the COLOUR MENU – AUTO DENSITY and set this to EXECUTE
  13. Check the COLOUR MENUCMY 100% DENSITY is set to ENABLE if you want a glossier black finish.
Feb 17, 2008 | OKI C5400 Laser Printer
Oki C5150N Grinding noise
One of the drum cartridges is stuck. Test by removing them one at a time with the printer off, then turning on.
Oct 31, 2007 | OKI C5150n Led Printer
Oki C9500 makes VERY LOUD clunking noises but prints fine...
The sound is most probably from one (or more) of the drum units. You can check by taking them out and trying to run the visible gears by hand. If you have spare drums, change them one at a time until you find the defective one.
Sep 04, 2007 | OKI C9500dxn Led Printer
306 people viewed this question
jasbo
jasbo
