Question about Dryers
My electric clothes dryer stopped heating. I checked the circuit breaker. I cleaned the lint tray. still no heat. next i will disconnect the hose in the back to check for blockage am i on the right path to fix this maytag 3 year old dryer?
  • Dryers Master
  • 7,482 Answers
Hi jonfremd...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Posted on May 26, 2011
Kenmore Elite Oasis ST electric dryer does not heat
You need to replace the heating coil that is usually the problem when you get air and and the tumbler is moving but no drying you can also check the lint catcher and clear out your dryer outgoing vent remove the hose check the dryer vent where the vent hose is connected and the vent going outside the house before changing the heating coil .
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Ml1987295
I will assume that you have cleaned the lint trap and checked that there is no lint stuck in the lint trap cavity
First, check the dryer vent. Any blockage anywhere in the vent will stop air flow. A dryer needs air flow to dry. Check every bit of it, even where it goes outside.
if that isn't the problem, then check your electrical connections. Your electric dryer runs on 220 volts, but it's really two wires carrying the electricity to the dryer at 110 volts each. If one of those wires isn't connected, the dryer could still turn on and spin, but it won't dry the clothes.
I learned that the hard way going through 2 dryers. Turned out one of the fuses in my apartment's fuse box had blown, but 2 fuses made up the 220v circuit. The dryer would spin and would work a little bit on low settings, but any other setting it would just spin and not dry at all. Replacing the fuse fixed the issue. With a breaker box, the 220v double breaker is connected, so if one trips, they both trip, and it wouldn't spin or turn on at all.
So check the socket with a multimeter (or have an electrician check it) and unplug and check the dryer cord making sure each connector is securely screwed in to the panel on the back. There is typically an access panel on the back of the dryer right next to where the cord goes in that you have to take off to get to the connection panel.
The last thing I would say a DIYer could look at is the heating element. If you take the back off, you can access the heating element and see if there is any lint or debri in there... if there is, clean it out and try the dryer... if it still doesn't work but there was debri in the heating element's channel, it could have burnt up a safty sensor that shuts the heating element off when it senses too much heat (fire, or potential to cause a fire) I suggest using and appliance repair man at this point.
Jul 31, 2014 | Whirlpool Dryers
My dryer we've had for about two months won't dry clothes. it heats up, but they are still wet four cycles later
I was thinking you have a bad circuit breaker. This dryer runs on a 2 pole 30 amp 240 volt breaker. The motor runs on one side of the breaker on 120vac. The heater has to have 240 volts to work correct. When that breaker is on the way out it will take a new dryer 3 or four times as long to dry the clothes. themobilian_294.jpg
If you are cleaning the lint filter out and don't have a clogged vent pipe themobilian_295.jpgthen in my opinion you have a bad circuit breaker. Seen it.
Nov 27, 2010 | Amana NDE2335AY Electric Dryer
I have a samsung dryer dv328aer that stopped heating up.
Check the home’s circuit breaker and fuses. Electric dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Select a heat setting other than Air Fluff.
Clean the lint filter and exhaust duct.
Another common cause of a dryer failing to heat is a faulty element (Heating Element). You'll need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 21, 2010 | Samsung DV328AE Electric Dryer
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
Our Kenmore model 96292810 clothes dryer has stopped heating. What is the likely problem?
Check the following to address this issue.
1. No power to the dryer(If you have power, skip to the next possible issue)
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 18, 2009 | Dryers
The dryer works but no heat.
2. Heating element
3. Thermal fuse
Jun 18, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer not generating heat and drying clothes...
Dear customer,
                We recommend you to do the following checks when your dryer isnt generating heat..
  1. Check for proper air flow
  2. Test the safety fuse
  3. Test the thermostats
  4. Test the centrifugal switch
  5. Test the timer motor
  6. Test the heating element.
Thank you.
May 09, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
Clothes aren't getting dry very fast
First, check your circuit breakers, turn them off and on...there are two linked together labeled 40 amperes or more. Next guess will be the thermostat or the heating coils. Use a multimeter to check these parts. A diagram is usually attached to the back of the unit. Oh, is the drum turning? Are your clothes reasonably damp dry when you put them in? Is the vent hose kinked when the unit is in place?
Dec 16, 2007 | Whirlpool LEQ8858J Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
