Question about Garden
I have a Bolens 1800 hydro eliminator, the electric clutch does not want to engage when the switch is turned on
  • 675 Answers
If you can...check to see if there is 12 volts DC on the leads that go to the clutch when you flip the switch...if so..then the clutch is bad...if not then you need to check the switch and the wires feeding the switch...also, make sure that there is or is not a fuse that protects the clutch circuit
Posted on May 26, 2011
I have. A. Bolens riding.mower.38inch cut 15.5hp model. Number 13AM662F765 an when I start it. Up everytime. The blades are in engaged an won't disengage why
If electric the clutch is hung and not disengaging or pto switch is bad and contacts are welded or stuck. If manual then the linkage to blade is out of adjustment.
Nov 17, 2017 | Garden
I have a 2011 Craftsman LT2000 Model # 247.288851. The blades will only engage when I raise the deck to level 5. Ive replaced the Seat Safety Switch so Ive eliminated that. Help please! Lol
what actually engages the blades an electric clutch or a manual lever both of my craftsman mowers have elec clutch and when you pull the button the blades run deck height has nothing to do with it .
Apr 08, 2015 | Craftsman Garden
Blade will not engage
There must be:
  • Someone in the seat
  • Not in park/idle.
  • A working blade start switch
  • A non defective PTO clutch.
  • Undamaged blade and greased blade bearings.
May 05, 2014 | Bolens 13.5 HP Manual 38-in Riding Lawn...
Bolens riding lawnmower st100 pto won't engage?
check for power to the clutch if yes the clutch could be bad or a wire going to it if no power check the safety switches
May 17, 2012 | Briggs & Stratton Garden
Hello, I have a Craftsman 46in. 18.5hp. lawn tractor that dies after releasing clutch or engaging the blades. I disconnected the harness from the coil. The tractor starts when on choke and runs on choke...
It sounds like from your first issue, regarding clutch and blade engagement probably is a safety switch issue. Safety switches are common on all lawn equipment and on other lawn equipment products due to OSHA. Make note of the harness that plugs into your seat, clutch pedal and PTO switch.
Un plug each one by process of elimination and test them with a test light or ohm meter for failure.
The most common issue is a little center block that is built into the plug of each switch, harness side.
Pull the plug and look at back side of plug. In the center is this small plastic insert with a small spring.
Use a small screwdriver and pluck out that insert and remove. Plug in and re test all your circuits.
Safety switches and safety systems do become problematic and it seems that your issue points to this.
That little insert is better known as a fail safe back up for the manufactures so that the consumer is unable to over ride or bypass safety features of the the unit in question..
Hope I helped! With 20 years experience in the Sears Lawn And Garden Department,, Best Regards,,
Scooter Tech....
Jun 11, 2011 | Garden
Bolens clutch wont engage
check to see if there is something caught around the blades that won't allow to turn
Jun 24, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a 2001 kawasaki 125 eliminator shuts off
If it dies when put into gear then its the side-stand switch (stand is down or switch not working)
If it dies when the clutch lever is released then either it was released too quickly with not enough revs, the engine doesnt have enough power to pull away or possibly the clutch switch is working in reverse
Good Luck
Hope this helps.
(If it does then please mark this as 'useful')
Ride Safe
Bike-Doc
Jan 29, 2010 | 2007 kawasaki Eliminator 125
Have a cub zero turn 52 inch cut the blades wont engage it starts but when you pull the switch to turn on the blades it wont engage any help?
sounds like one of three possible problems ....one - there are safety switches that prevent engagement of the blades,,,,,two - the electric switch which engages the electric clutch blade pulley is bad....or three - the electric clutch blade pulley assembly is bad.....first.....make sure all ur connections are tight to the safety switches and electric clutchblade pulley.....then, if your able to read and follow a wiring diagram, get the wiring diagram for your tractor and a 12 volt probe light (with probe point end) with a ground lead....first, ground the clamp end to the frame and probe at the electric pulley clutch plug to see if power is getting there...if not...follow the wiring diagram to the next switch location the power lead comes from....if one side of the swtich shows power and the other side doesn't with the switch in the correct run position....then the switch or connection is bad.....if it probes okay...go to the next switch....follow this logic from both sides of the from the electric pulley blade clutch plug until you isolate the switch or plug problem....if everythin tested is good....then it's the electric clutch pulley assembly that need replacing.....hope this helps.....
Jun 07, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
465 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
