Question about Cameras
Nikon D80 err message shows "lo f5.3" how do I fix?
  • 11967 Answers
SOURCE: Nikon D80 Err- No pics!!!
Check Nikon for updates.
Posted on Aug 23, 2009
SOURCE: malfunction D80 showing erratic "Lo " message,
if you're in a P mode it means it in low light condition. whne you see the Letters "LO" and take a shot it woudl take time before the camerea releases the shutter because it's automatically exposing the image and exposure may take longer depending on the lighting condition.
Posted on Jun 10, 2008
SOURCE: Nikon DSL D80 with "r02" error
normally, just removing the lens and putting it again you solve the problem. F-- problem means "there's no lens attached !"
Posted on Mar 17, 2009
  • 181 Answers
SOURCE: Nikon d80 shows err message. still after full reset it wont work
Check if your battery is charged. Are there any error messages? Otherwise, if your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
To fix this error, try this:
1. Turn off camera
2. Turn the aperture ring clockwise and then lock it
3. Turn on the camera
If you still encounter the same problem, repeat the same steps but turn the aperture ring counter-clockwise. Hope this helps.
Posted on Jan 08, 2010
  • 65 Answers
SOURCE: err message showing up on screen. Therefore cannot
sd card needs to be replaced
Posted on Jan 19, 2010
Nikon d80 camera shows err error, when shutter is pressed the amount of shots remaining, shows er07. shutter works, but no picture is taken. Bracketing sign is also on display and wont go off.l
failure of the aperture unit is the usual cause - usually the contacts for the phase switch have come loose from the gear. You can find info on this by searching for the problem on the internet, including how to repair it.
Apr 06, 2013 | Nikon D80 Digital Camera
My nikkon d80 is showing err what ot do
This is a very often asked question. The answer has been posted many times on this site: The ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
Aug 29, 2010 | Nikon D80 Digital Camera with 18-135mm...
D80 err message . what can I do to fix without sending the cam in? I have already did the reset and nothing so far is working..
Page 132 of the D80 manual states the ERR is a camera malfunction. My suggestion is to rest the camera, see if that helps you will find those instructions on page 129 in the D80 manual. Sometimes removing the batter then pressing the shutter release numerous times will free up any static buildup. If none of that works it is off to Nikon.
Jun 20, 2010 | Nikon D80 Digital Camera with 18-135mm...
Err problem
May 12, 2010 | Nikon D80 Digital Camera with 18-135mm...
Error message on D80 Nikon
To assist you we need more information than you provided. For the ERR message read page 132 in the D80 manual.
Apr 13, 2010 | Nikon D80 Digital Camera with 18-135mm...
My nikon camera keep got error and dont have the
You have not provided enough information, what is the error read? If it shows ERR then: The ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
Mar 24, 2010 | Nikon D80 Digital Camera with 18-135mm...
Err with f4 and r11 display
If your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
1. Turn off camera
Nov 27, 2009 | Nikon D80 Digital Camera with 18-135mm...
Cameras Logo
186 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
