Food Mixers Logo
A
Anonymous Posted on May 26, 2011
How do you remove and replace the small gear pulley on a Kenwood Chef KMC510?
2answers
Kenwood Chef Premier can run at all speeds for the first few seconds. Then it runs slower and you can tell by the sound.
It sounds like there may be an issue with the motor in your Kenwood Chef Premier mixer. This could be caused by a variety of factors, such as a malfunctioning motor, a problem with the drive belt or gears, or an issue with the electrical components of the mixer. To troubleshoot the problem, you may want to try cleaning and lubricating the drive belt and gears, as well as checking the electrical connections and fuses.
I am looking for the plastic drive pinion gear for a Kenwood Chef A701A
http://www.trademe.co.nz/home-living/kitchen/small-appliances/mixers/auction-1198693935.htm
1helpful
Kenwood chef service in India?
I am having KENWOOD CHEF MODEL A901D capacity 3IMP,QTS 3.4Ltrs purchased from UK around 26yrs back.Now it is asking some small repair please advice me your authorised service centre in Hyderabad,[Andhra Pradesh] India. Or any other parts of India.My E mail id is [email protected]
Mine is a Chef Stand Mixer but really don't know model no. Where to find?
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause leaks.
To lubricate the unit, you need to spread again the grease in the gearbox, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
3helpful
Kenwood chef A701A mixer not working but blender does
could be one of three things
1) the belt is broken to the main gearbox (fairly easy to replace if you can get one)
2) a gear has slipped or broken which means none of the front end will operate.(I have this problem and cannot get the gear body to open)
3) If the top and front worms are turning then the problem is with the planetary gear which again is fairly easy to replace
Bill N
3helpful
2answers
I have attachments (Mincer and pasta maker)for a Kenwood Chef 901 E that fir onto the front. However these attachments don't seem to fit onto a Kenwood Chef 701 A - the hole at the front seems just a...
Hi ...
all Attachment for models A700D. A701 / A , A702, A703
NOT fit in models A900 ahead
anyway, the front of kenwood A900, and KM series its same, you can fit, but not of the models A700/701/702/703C
in http://www.kenwoodchefrestore.co.uk
you can see the compatibility of attachments
Regards
2answers
My kenwood mixer will not mix, the liquidiser works ok but the mixer rotates very slowly.
Hi, maybe you have 3 problems:
1 the tooth belt its nearly broken.
2 Problem in some gears
3 If its model A701/A check the back cover, and the pin in the top. its in good condition
regards
Kenwood Chef Restore
2helpful
Kenwood chef.mixmaster
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Top Kenwood Food Mixers Experts
vince
Ngoro
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
