Question about Emprex LM2201 22" LCD Monitor
How do I fit the desktop to the full screen of the monitor?
  • 92 Answers
Before you change your screen resolution, you should know first the dimension of your monitor..
this is the common screen resolution for 22 inch LCD monitor: 1600 x 1024 1920 x 1080 up to 3840 x 2400
Note: You can only use this resolution if your video card supports this given screen resolutions. You can set your resolution through configuring the display setup.
Posted on May 26, 2011
Cannot fit to screen size
You probably need to install a display driver for this monitor on your netbook. http://us.aoc.com/monitor_displays/e950swn
Dec 05, 2012 | AOC 19" LED Monitor e950Swn Black
Tip
How to resize your desktop background.
If your desktop is smaller than the dimensions of your monitor then follow the following steps to get a full screen:
Setting the resolution:
1) Right click on an open spot on your desktop and select Properties at the bottom of the popup menu.
2) This will then open up the Display Properties window as shown below.
3) Click on the Settings tab (it's to the top right of the Display Properties window as shown in the image below.
4) At the bottom left of the settings tab there is a Screen resolution heading with a slider bar beneath it.
5) Slide this bar to the left or right until you find the resolution you like.
6) The click Apply when you have found the right resolution.
Sliding the bar to the left = lower resolution, larger desktop icons and less quality.
Sliding the bar to the right = higher resolution, smaller desktop icons and better quality.
NB: If you are using a CRT (older screen) the max resolution will be around 1280x1024. Newer LCD screen (flat and thin monitors) can go way up to 1920x1080 and beyond if HD is supported.
NOTE: If when doing the screen resolution changes your screen goes blank after you click Apply then immediately hold down the Enter key to restore it back to your previous settings
If this doesn't work then it just maybe the case that you need to set the auto screen fit function on the monitor itself using the buttons provided on the monitor.
This tip is useful when you plug in a monitor and the screen displays the No Signal or Signal out of Range massages. Simply change the resolution to something the monitor can handle and there you go.
You can also check out my video tutorial if you want to:
on Nov 10, 2010 | Computers & Internet
My desktop is only showing a strip of the picture. Everything else is fine. What can I do to restore my full picture on the desktop?
I'm guessing ur talking about background picture. Am i right?
In that case, you have to set your background picture, in order to fit the desktop. You can do it using left click on ur bakground and select Personalize -> desktop background, where you can find options "Fit To screen", "Tile" or "Center". Select "Fit To screen", then press ok. this should do it.
If you are using Vista as operating system. Before Vista, it varies where you can find the setting windows.
Mar 06, 2011 | HP Computers & Internet
Pop up of monitor adjust screen
Hi, you probably have to set the correct resolution that fits on your monitor. The correct resolution is: 1920x1200 You can set it by right-clicking on your desktop and choosing "Screen Resolution" in Windows Vista and Windows 7. If you use Windows XP, right-click on your desktop and choose "Properties" Then open the rightmost tab to choose the resolution
Jul 19, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
I just installed hasbro classic game collection on pc i have a 19" widescreen aoc monitor and when i try to play monopoly i can not see the whole picture it is like it is long and narrow and the game will...
before you start your game, you can try to modify your screen resolution and then start the game it will fit to the new screen size.
depending on your OS (winodws)
WIN XP close all windows and place your mouse over your desktop right click and select properties. a windows will pop out with the following tabs THEMES, DESKTOP, SCREEN SAVER SETTINGS.
click on settings and you will see a computer screen(s) and it will be a place to change the SCREEN RESOLUTION (800x600) (1024x768) etc try a diffrent one from the one you are using and click apply and then OK. run the game, if it persist just try a different size.
WIN VISTA click on desktop area and sellect PERSONALIZATION, click on Display settings and change the RESOLUTION.aplly and ok.
if my advice was of any help please rate me :)
thank you
Oct 07, 2009 | AOC 22" Widescreen LCD Monitor
How do i adjust size of desktop background to fit screen
If you are using Windows Vista right mouse click on an empty area of the desktop and select personalize. Click on the tab for background and there are options there to fit to screen, stretch image, tile, etc. Select the stretch image and then apply. It will make the image fit your entire desktop. If you are using Windows XP it would basically be the same steps exceot when you right click you would select properties. Hope this helps.
Aug 09, 2009 | Computers & Internet
My icons and tool bars are so big nothing I bring up fits on the screen.....I can make the internet smaller with the mouse wheel, but it shows in a very small space because of the very large tool bars....
Here are some tips to help you move around when you can't see other parts of the screen
Alt + Tab (hold down Alt and press tab) will move you between open windows
Tab will move you from button to button and to the file menu at the top
Shift + tab will move you back, for example if you hit the tab key one too many times
Alt + F4 will close the open window, if no window is selected it will bring up the shutdown computer screen
F5 will refresh a page on the Internet
F11 will switch between Full Screen mode and not full screen mode
So try getting to the "approved" window and then using tab to select it.
Mar 11, 2009 | Gateway GT5056 PC Desktop
How to stretch screen compaq tft5015
Right click the desktop - select graphic properties - you should have the option to stretch to fit or something like that. This could also be that your resolution doesnt match your monitor. usual wide screen monitor defaults are 1280/1024 or 1400/1068.. have a mess around and alter these - see which one fits.
Jan 25, 2009 | Compaq TFT5015 15" LCD Monitor
Windows XP not fitting full on 22 inch computer screen
Your new monitor will show a "native resolution". In the instructions below, try that setting first. If that fails try other settings.
- Right-click on an empty spot on your desktop
- Chose "Properties" on the menu that appears
- Click the "Settings" tab (at the top right)
- Move the "screen resolution" slider to a different number
- Click "apply"
- See how you like it
- Repeat until you get a setting you like.
Dec 27, 2008 | Computers & Internet
Emprex LM2201 22" LCD Monitor Logo
166 people viewed this question
Top Emprex Computers & Internet Experts
David Payne
David Payne
Are you an Emprex Computer and Internet Expert? Answer questions, earn points and help others
