Question about BenQ PB6100 Multimedia Projector
Color problem I have about 350 hours on my Benq PB 6200. After viewing a movie for 15 minutes the color wigged out. colors faded except for heavy blue. Then the screen went white for several seconds, and then the lack of color got worse. It almost became a old black and white movie. Turn the projector of properly, waited for 15 minutes. Started it up again, looked great for 2 minutes and started the problem all over again. Tried a different DVD player, but to no avail. Please advise.
  • 44 Answers
Check the cables connected to the back of the projector. reinsert the cables a few times to get a good contact. Jiggle the connection at the projector to see if there is a bad connection, do this while viewing the image on the screen. If everything is good and no response to the connections, It might be the main/input board is bad and will need replacement.
Posted on Aug 16, 2008
Fading color
Unplug your television set from the wall socket and leave it off for 24 hours or more. Then reconnect the power and check if the problem disappears.
Nov 10, 2013 | Televison & Video
Why do people color their hair?
These days hair coloring is a huge industry with a reported 75% of women in the States coloring their hair in some way. People don't just do it to cover up grey (although that's a large percentage). Hair coloring is also used as a way of expressing fashion and identity.
Jan 10, 2013 | Health & Beauty
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
Printing faded color text on my color paper...
That stock might be too heavy for a bizhub.
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb)*, OHP transparencies*, postcards*, letterheads,
colored paper, envelopes*, label sheets*, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray?
Jun 09, 2008 | Office Equipment & Supplies
Color loss
Your formatter or what is called the FMT board has bad capacitors on it.
May 23, 2008 | Mitsubishi WD73727 73" HDTV
Color fades
HELLO. it sound's like you have a cold solder problem.!!! what that mean's is that when the set get hot .!!! it lose's it's contack.!!! you might try going over the chassis .!!! soldering the conteck's.!!! with a low watt. solder gun.!!! not over 40 watt's.!!! and use 40/60 rosin core solder.!!! hope this help's you .!!! "GOOD LUCK"
Mar 14, 2008 | Hitachi 50UX58B 50" Rear Projection...
Sharp Aquos Color Variations
Put the OPC off and check the conection for Pb signal.
Nov 13, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Color fading to black and red "nightvision" picture
We have a 60" panasonic rear projection television and the color fades in and out. What do you think is the problem the tv is only two years old and is now starting to apear in black and white sometimes. What can be the problem?
Oct 03, 2007 | BenQ PDP-46W1 46 in. HD-Ready Plasma...
Tv shuts off
When you let it sit for approx. 15 minutes it will come back on and usually stay on. I've also noticed that the color will fade in and out at times. during 15 mts of your sitting do you get sound & less brightness then problem in video or luminance section. if picture is dim & color will fade in and out at times then possibility of crt is getting less voltage on g2. if set is old then there is a possibility of crt getting weak. but if the above things are not there then problem in power supply. good luck
Sep 22, 2007 | Mitsubishi VS-55707 TV
BenQ PB6100 Multimedia Projector Logo
261 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
