Question about Marantz PMD320 CD Player
Whilst the cd drawer was in the open position I caught it with my knee leaving the drawer on an angle. When I press the close button nothing happens and any attempt to close manually is met with resistance. Any suggestions would be appreciated.
  • 675 Answers
Drawer is out of alignment...some players have timing marks to align the gears(similar to engines)...but without a service manual..it may be complicated...you can try to realign the drawer...there is a limit switch that tell the player when the drawer is fully open and one that tells the player when it is fully closed....a good way to try to realign is to move the drawer one tooth at a time and trying it..until it lines up
Posted on May 26, 2011
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
Unlocking my DVD player
some others
new model pacific 1002mk2 (ASDA) using remote.;
press open on remote
press clear
press 1-3-6-9 Then 0(for multiregion)
Press close
It's important to note that you will not see anything happen on screen or display!
The buttons are small,so you'll have to be precise
1. PUT A REGION 2 DISC IN PLAYER
2. WHEN IT IS LOADING UP PRESS "SETUP"
3. PRESS "7" FOR MULTI REGION
4. PRESS "PAUSE/STEP"
5. PRESS PREVIOUS " |> "
6. PRESS SETUP
YOUR PLAYER IS NOW MULTI REGIONAL.. IS YOU WANT TO SET THE REGION IN STEP 3 PRESS 1 FOR USA OR WHATEVER YOU REQUIRE....
or
switch on.on the remote press "open/close",0,1,2,3,open/close and it plays straigt away. but nothing is shown on the screen.
or
It's true - a quality DVD player from Asda for £59.95. Highly recommended. This 1359 hack worked with my Pacific 1002 purchased March 03.
Note. There is no on screen display or any indication on the machine when entering the hack.
Switch machine on and using the remote control only:
1. Press 'open/close' button (the draw should be left open).
2. Press the 'clear' button.
3. Press '1'.
4. Press '3'.
5. Press '6'.
6 Press '9'.
7. Press '0' (zero for multi-region).
8. Press 'open/close' button.
End.
or
1. switch on dvd with remote (leave drawer closed)
2. Press: setup
3. press: 7 (note nothing will happen)
4. press: pause/setup button (again nothing will happen)
5. press: previous/I<< button (nothing will happen)
6. press: Next/>>I button (nothing will happen)
7. press: setup
Dec 05, 2007 | Televison & Video
Whilst putting cd into my hi fi accidentally pushed close button drawer closed before cd properlyinserted. Now I cant open to get cd out
Look close, many times there is a tiny hole the size of a needle by where u put the CD in.
Pop a needle in there and it will release the CD as it opens the door.
Oct 19, 2015 | Televison & Video
How do I fix my computer CD writer Drawer to make it open.I banged it with my knee when it was open,I pushed it closed and does not open any longer.Its the HP 583 Pavillian model,not new but works wel
Many times you will see a small hole next to drawer, try something thin lika a paperclip & give a gentle poke inside. Feel for a button type spring response.
Oct 15, 2014 | Computers & Internet
MHC-RG270 cd draw won't open
cd drawers often jam.
In the cd/dvd drawer you will see a small hole. Use a blunt pin or a straightened-out paper clip, insert it into the small hole and gently press. The drawer should then click open.
Try cleaning the plastic drive teeth/mechanism with a light drop of oil. Press the drawer button and it should then close. Press it again to see if the drawer opens as per normal.
If your cd drive plays a dvd as per normal but doesn't open when the button is pressed, continue using a blunt pin/paperclip. If the plastic open-close mechanism is worn or damaged there's very little you can do about it expect replace the entire drive.
Feb 01, 2014 | BenQ FP91G+ 19" LCD Monitor
Home theatre (panasonic SA-PT460) drive wont open makes some noise when i press the open/close button as its closing. I unscrewed the device and removed the dvd tray from its case as i pressed the...
I also have a problem with the drawer. It opens when I switch the unit on and when I close it - it opens again!
If I switch off at the mains the drawer remains open - to prevent dust ingress I have resolved to holding the drawer in whilst shutting down the power until I get a solution.
If anyone has a solution I would be grateful.
Sep 08, 2011 | Panasonic SA-PT460
Wrong region message
power on.
open the drawer & LEAVE IT OPEN
press on the remote control
1 3 7 9
four small stars appear in the top left of the screen whilst you enter the code chose whatever region you want 0 is region free
once the code is entered simply enter the region number you require, close the drawer & press play
Mar 31, 2011 | Daewoo DVG-8500N DVD Player
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
The CD Tray won't open on my Sony MHC-GX250
te same thing happened to me know i juat turn the stereo off to where the red light is blinking then turn it back on after the standby message disappears and then i quickly pree the eject button......tr it! and let me know!
Jun 24, 2009 | Sony MHC-GX450 CD Shelf System
Marantz PMD320 CD Player Logo
166 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
