Question about Clarion Car Audio & Video
I just brought clarion cd player had it fitted by vauxhall dealer and when i put the key in the ignition turn key to aux cd wo'nt come on but when you turn the key to start engine cd player works,should be able to use cd player without to having engining running need help so i can go back to vauxhall dealer tell then what to do.
  • 675 Answers
Sounds like the unit was not wired into the car properly..the dealer needs to make sure that the switched lead that they connect the red wire from the radio to is hot when in both run and aux(accessory) positions on the ignition switch...it sounds like they may have wired the switched lead to the wrong accessory lead
Posted on May 26, 2011
Is there a way to wire in for an ipod
Only way would be via a FM modulator which I would not recommend. There is no Aux input cable or port on the XMD2.
I would recommend upgrading to a newer model with full ipod control and charging capabilities. Any Clarion dealer can help you with that.
Feb 04, 2011 | Clarion XMD2 CD Player
I bought second hand clarion EQS560 I need to know the connect for AUX or RADIO input is it from cd speaker out put wire or player output wire
1. bottom right( red wire 12 v dc on/off ignition switch)
2. top right( blue wire with inline fuse to amplifires)
3. bottom left( black wire ground)
4. top left( blue wire stereo remote wire
for further help look up
http://www.teamclarion.com/sharedwebdbs/clarionsupport.nsf/7c4539c6b00a28d488256a4c00781d7b/44c74b3b34df7a2088256a64006efba0/$FILE/EQS560%20(OWNERS%20AND%20INSTALL).pdf
Dec 01, 2010 | Clarion EQS560 5-Band Car Equalizer
Fitted clarion db148r car sterreo(pluged in at rear) when i take ignition key out stereo switches off and all preset radio stations are lost thanks george
The reason you are loosing all of your presets, clock & eq settings is because the 12volt constant is not hooked up properly. The red wire in the harness needs to be hooked up to 12 volt consant. The yellow wire needs to be hooked up to a ignition source. By taking these two steps, you should have normal operation and preset retention.
Sep 13, 2009 | Clarion DB148R CD Player
I installed a clarion cd player now cd plat doesn't shut off
THe red wire is to be connected to power from the ignition.Meaning this wire should only be hot, when the ignition is on..
Sep 07, 2009 | Clarion DB538RMP CD Player
I have a Clarion installed in my boat. Sirrius, cd am fm. No jack to plug in iPod. Solution?
FM Modulator.
(clarion makes a hardwire direct connect one)
FM200
You would use a 3.5mm to RCA adapter
There are also battery powerd ones (Belkin)
Either one is used by simply tuning in to an empty (white noise) radio station.
Im assuming the XMD3-RET is not the radio you are inquiring about since you described Sirius as a feature.
Some clarion radios have an AUX input or changer port that can be converted to an ipod cable.
If you reply with a model # i can look it up for you. I am a Clarion Dealer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Apr 14, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
My radio wont turn on
sound like you have a bad fuse in your aux wire check to make sure your aux wire has power when ignition is on if not check your fuses in your car start with the radio but it could be drawing from another fuse like cigar lighter good luck.....
Dec 31, 2008 | Clarion DXZ865MP CD Player
Steering wheel controls
no sorry no waty they will work thanks jezza
Oct 19, 2008 | Clarion DXZ848RMC CD Player
My Aux-in wont work
did you turned aux function?
turn off your player by pressing and holding volume controler.
press and hold longer (~5 sec) it again to turn it on (you should see 'tuner' in the lcd).
push up arrow to select aux and right/left to turn it on.
now you can connect your ipod and select aux (as ussual switching between tuner/cd player/aux)
cheers :)
Aug 22, 2008 | Pioneer DEH-30MP CD Player
Clarion radio wiring diagram
Usually the yellow is for ignition switched-red is permanent +...;)
Aug 03, 2008 | Clarion ARX6670Z Cassette Player
In car sony radio cd player
Connect the permanent power line that goes directly from the battery to the "Back up" wire of the CD Player.
Mar 05, 2008 | Sony CDX-M610 CD Player
Car Audio & Video Logo
134 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
