Question about HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory
Receiving Service code 49.4c02 on HP 4650 color printer
  • 4 Answers
SOURCE: Service Code 49 4c02
Try to upgrade the firmware on the printer, if that error still occurs after the firmware upgrade, you should try and use PCL driver rather than PS driver.
Posted on Sep 18, 2009
  • 214 Answers
SOURCE: HP Laserjet 4650 color printing problem
More than likely you need new drum.
Posted on May 06, 2009
pdouglasss
  • 125 Answers
SOURCE: hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has
occurred that caused the
processor on the formatter
to abort operation. This type
of error can be caused by
invalid print commands,
corrupt data, or invalid
operations. In some cases,
electrical noise in the cable
can corrupt data during
transmission to the printer.
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
printing a different file. If
the message appears
only with a certain
software program or
print job, contact the
software vendor for
assistance.
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
DIMMs from the printer.
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
pdouglasss
Posted on Jan 10, 2009
  • 1121 Answers
SOURCE: how to do borderless printing with an HP 4650
change the printer margins
Posted on Dec 22, 2009
  • 62 Answers
SOURCE: When trying to print on HP 4650 printer stops and
update the firmware first...if problem persists try removing the jetdirect card..if error goes away your jetdirect card will need replaced
Posted on Jan 06, 2010
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
Message "card slot not initialized
The HP Color LaserJet 4650 printer also has three flash memory card slots for printer firmware, fonts, and other solutions. The HP Color LaserJet 4610n does not include any available flash memory card slots.
■ The first CompactFlash slot is reserved for printer firmware.
NOTE Use the first flash memory card slot for firmware only. The slot is marked “Firmware Slot.”
■ The two additional CompactFlash memory slots in the HP Color LaserJet 4650 printer enable the user to add fonts and third-party solutions, such as signatures and personalities. The slots are marked "Slot 2" and "Slot 3."
--- These card slots are located inside the Formater unit. Most likely you either are missing the firmware card or it's defective.
Hope this helps!
good luck!
Aug 31, 2009 | HP LaserJet 4650 Color Printer
HP 4650 stops at "initializing"
REMOVE THE BATEERY IN THE CARD AND DO COLD RESET
Apr 20, 2009 | HP LaserJet 4650 Color Printer
Business cards get stuck in HP 4650
The card stock is most likely too heavy for the 4600. If you check the owners manual, you will most likely find this is "Out of media specifications".
Other color HP laser printers like the 2500 cannot move card stock well either.
HP will tell you that 'if the printer moves paper perfectly' it's not broken.
Mar 12, 2009 | HP LaserJet 4650 Color Printer
Instructions for replacing Paper Pickup Assembly on an HP 4650
Try this website. www.feedroller.com. On there, if you go to HP, there's a lot of service manuals you can download,one of them being the 4600/4650. This will assist with every aspect of removal and replacement
Feb 18, 2009 | HP LaserJet 4650 Color Printer
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
or home-grown
programs. On rare
Error.
the printer memory.
then on.
different software
program. If the job
the message appears
only with a certain
software program or
software vendor for
assistance.
or computer.
6 Remove all memory
from the printer.
DIMM and EIO device
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory Logo
1,122 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
