Ihave a haier model cpr10xc9-l portable ac. I is leaking water from the vents at the bottom.It seems to build up water under the condenser on top and will not evaporate it like it is suppose to do Any Ideas. Thanks
  • 11,800 Answers
In this unit the water that is condensed from the air is collected in a tank and evacuated by evaporation thru the air outlet. But this system has its limitations: if the air humidity is above 85% this procedure can no longer work and the water accumulates in the drip tank.
So either the tank is full and must be emptied or the drip tray under the condenser has its outlet hole clogged by dirt and it will have to be cleaned.
The water is eliminated thru a simple plug at the rear, at the bottom - place a shallow pan and take out the plug. To clean the outlet hole insert a thin and long zip-tie in the plug at the rear and gently twist it around going in and out until the plastic band end up clean. Finally just plug it back and start the unit. This procedure will have to be repeated at least once a month.
Posted on May 26, 2011
We got a new Haier AC 8000btu window unit runs on 110plug in used 1summer an2months now new from Wal-Mart was working great now it's misting in water an drips are building up on the bottom inside help
there will be a drain hole on the outside bottom part of air conditioner to drain the condensation out of the device. It might be a hose or a small pipe suggest checking it for blockage .
Jul 20, 2016 | Haier Heating & Cooling
Water is leaking from the floor vents what could be the proble?
Check your heater radiator. It is usually mounted behind/near the glove box areas on most cars. It is like a small version of the large radiator that is mounted on the front of your vehicle under the hood. Antifreeze and coolant (does it smell a little like antifreeze?) flows thru your front radiator, thru the block and hoses, and cycles thru the radiator for your heating system. If the radiator is leaking, often it cycles thru the vents on the interior.
Another possibility MIGHT be the AC system and condensation/AC coolant that is building up in/on the lines and transferring thru the vents.
Aug 18, 2014 | 1999 Buick LeSabre
Fills with water, doesn't evaporate. Leaks. HAIER HPR09XC7
There is nothing to resolve. Your humidifier is working properly.
A humidifier works by condensing water out of air. This is the job of the cold coil, which you have found to have water dripping off. The Warm coil is not intended to re-evaporate the water, as this would just bring the relative humidity back to the origanal high level, rather, the warm coil is used to re-warm the air, going back into the room so the room does not get too cold. It is normal to have to empty the bucket and restart the process on a periodic basis.
Jul 20, 2010 | Haier HPR09XC7 Portable Air Conditioner
Portable AC leaking
depending on where you live. do have high humidity. then you have excess amount of water that might make condensate. like very cold can of can of coke.
Jul 11, 2009 | Soleus PH310R03DB Portable Air Conditioner
Sharp air conditioner portable leak in bottom
You mean it's leaking around the AC's unit base? If so, here's a handy diagnostic article that specifically addresses this problem of yours, explaining the probable causes and solutions, a solution that may very well have to do with the condensation pump's malfunction or just debris blockage, among other things: http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Creates_Water_Puddle.htm This article should set you on your way! Good luck! Brad
Jun 13, 2009 | Sharp Heating & Cooling
My haier a/c window unit is spitting water through the vent
Thermal transfer-the unit is creating condensation.
Jun 03, 2009 | Haier Heating & Cooling
Condensate blown out of the AC vents in front of passenger seat
U need to crawl under the car and clear the ac condensate drain, it is a rubber pipe on the passenger side that sticks out of the bottom of the engine firewall, they get clogged and water builds up in the ac and this problem happens.
May 14, 2009 | 1999 Mitsubishi Montero
Water leaking in refrigerator on shelves, drawers, and under draw
We took the back bottom vent cover off. Clean that area of lint. We than followed the advise given to another posting of a refrigerator link. This has seemed to work for now, time will tell. However we were told most people with Haier refrigerators have problems. Thank you.
Feb 15, 2009 | Haier Refrigerators
Haier AC HWR10xc6
Haier Air Conditioners do not have a drain hole or hose like most A/Cs. This problem can easily be solved by carefully drililng about an 1/8 or 1/4 inch hole in the bottom outside edge directly on the metal frame, around the cooling fins.... This will elt the water drain out...if you when outside and looked in while it was spitting you would see the water pooling up in there. Haier expects us to mount these units at an ungodly angle to drain the water, but drilling a small hole will help (really anywhere in that bottom plate would work since the whole bottom is a "drain pan"
Aug 30, 2008 | Haier hwr10xc6 Air Conditioner
Water builds up on the passenger seat floor when the a/c is running
the vent for a/c is block and leak inside it suppose to leak outside open the hood on the fire wall on passager side at the bottom you should see a rubber hose clean that hose its full of dirt you probably see water leak out that condensation from the evaporator (a/c) system hope its a fixya thanks pierre
Jul 31, 2008 | Mazda Protege Cars & Trucks
Heating & Cooling Logo
204 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
