Question about HP LaserJet 1200 Printer
Hp lj 1200
Blinkng green light seems to appear while trying to print but sooner it stays permanent green on the printer as if it's not printing
the printer icon comes up on the system tray area and goes pff immediately
  • yoninets Oct 29, 2008
    where is the solution at all; i followed all the links to the solution but no solution shown up
    am afraid the solution is "How much price HP lj 1200 at sisney-Astralia" if so sorry pvthuy1965 and shame on u
How much Price HP lj 1200 at Sisney- Astralia?
Posted on Aug 16, 2008
There is an error code on my HP LaserJet P3015 which reads 49.4C02 ERROR
HP LJ P3015 with 49.4c02 error - tried lots of things in the end went into printer driver right clicked and then clicked troubleshoot - windows came up with a fix dont know if it is permanent - troubleshooter said a print job was deleted from the print queue. Presume the printer tries to print the problem job in the queue each time it is switched on.
Oct 10, 2013 | HP Laserjet P3015X Printer
LJ P3005, will not print from tray 2. Tray 2 is
Do a factory reset then reconfigure device one more time.
Jan 24, 2018 | HP LaserJet P3005n Printer
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Feb 26, 2009 | HP LaserJet 4 plus Printer
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    Hp laserjet 1200 series
    Remove the DIMM and reseat it.
    If the printer still has an error, replace the DIMM.
    Unplug the power, reseat the paper tray, and reattach the power cable.
    Oct 20, 2008 | HP LaserJet 1200 Printer
    HP Laserjet 1320n Error Lights not in Manual
    hi friends......
    shivachadra is here.....just i faced this problem "Attention, Ready, and GO LEDs are on solid"
    and i got solution in troubleshooting....just vi refixe the connetion of laser scanner........its the error of comunication between laser scanner and formatter....
    May 27, 2008 | HP LaserJet 1320 Printer
    Wrong Port when printing
    assuming you mean you are connecting to two separate parallel ports, then your bios settings may have not been set correctly(duplex operation - bidirectional data allowed) or your ports may have been moved by other added hardware, ie your bios may be poor at doing that especially if the parallel ports are on add in card. but since you gave us none of that information, i would try uninstalling both then just add the 1200 first on the first(other) LPT. see what it manages on the one that works on its own. if its ok which it should be then try adding the 1500 after see what happens to both then.
    Dec 19, 2017 | D-Link DP-300U (DHDP300U) Print Server
    HP LP1020
    ok, y solved linking the printer with the application provided with the dpr, PS-link, its added a new port and printer and works fine since. hope helpfull
    Sep 12, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
    HP LaserJet 1200 Printer Logo
    137 people viewed this question
    Ben Johnson
