My Kenmore Elite Smartwash SteamCare Quiet Pack 9 is continuously given an F21 code message. Few minutes after the cycle start he code appears and I have to disconnect and reconnect from the outlet in order to be able to open the door just to find that the clothes are soaked in water... I need help rush!!!
3 Suggested Answers
  • 3 Answers
SOURCE: Hello:
This is super easy but can be messy. Get some rags or a very shallow baking sheet because some water may drain onto your floor. Turn off and unplug the washer for safety. All your doing is removing three screws with star screwdriver, unscrewing a canister inside (by hand), cleaning it out, and putting everything back. Here are the detailed steps:
There are three screws at the base of the washer. Theses screws hold the bottom panel in place. You will need a STAR head screw driver. Most screwdriver kits come with them, or you can get one at any local Radio Shack or Home Depot. Remove these three screws and remove the panel.
Put your catch pan or rags under the middle of the machine. There's not much room so you may have shove them in there.
There is a large white plastic canister that has one tube going in and one tube going out. The front of this screws off/on. Gently unscrew (by hand) the canister. Water will probably begin draining. It will stop shortly, but if it gets out of control, just screw the lid back on and go get what you need to catch the excess water.
After you have unscrewed the canister, you may need to pull the lid towards you a little. You will soon see why. I was so surprised at the amount of yuck that had collected (coins, broken pencils, bugs, lint...). Remove the obvious yuck and put everything back. That's it. Plug washer back in and turn it on.
Posted on Jun 11, 2010
TheMobilian
  • 8220 Answers
SOURCE: I have a Kenmore
You should do the old filter cleanout. Remove the base panel and get the junk out of the pump filter.
How to video
Posted on May 26, 2011
Kenmore elite smartwash quiet pak 9 he4t won't engage when start button pressed.
The start button operation could be erratic, indicating the need for replacement.
Dec 12, 2016 | Kenmore Washing Machines
Kenmore elite smartwash quiet pak 9 he4t the washer starts filing water when the washer is turned off.
This is symptomatic of a malfunctioning water control valve- not closing fully- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 19, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite is now LOUD during spin cycle
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 11, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
He4t kenmore elite smartwash quietpak9. keeps flashing F2?
"F02" is a Long Drain error. This is an indication that there's an obstruction somewhere in the drainage system. Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the bottom front edge of the lower toe panel directly below the door. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Mar 02, 2010 | Washing Machines
Wash cycle stops, F21 error message appears
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Sep 11, 2009 | Kenmore Elite HE5t Washer
I have a kenmore elite smartwash quiet pak9 he4t water wont drain on the final rinse cycle. The only error message i get a the letter F. Does anyone know what that means?
Dont know the code but i would imagine it means the water has not emptied in the max time preprogrammed,either the drain is slow or blocked or drain pump is faulty
May 04, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite smartwash quiet pak 9 he 4t seems to be off
have you tried lower spin speeds? I found with heavy items such as towels and jeans it is best to lower the spin speed. also washing like heavy items on a certain wash cycle is best - i.e. towels on bluky/bedding.
hope that helps.
Apr 08, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
157 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
