Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
What is that most critical part of the mother board..what is the most important part of it, that if become damage will totally stops its functions?
  • 60 Answers
A Motherboard has several parts that have to be in a good shape so that everything works.
Lets compare the MOBO (motherboard) with a car engine. The Mobo would be the block... now if it does't start it could be the battery, the starter, or just no gas in the tank.
To go back to the Mobo issue, the most important part is RAM (Random Access memory) and the CPU (Central Computing Unit)... and of cause the Power Supply.
Most of the Motherboards nowadays have BIOS posts which will indicate you where the problem is...it will scan through the setup and post a OK on your screen while in boot up. If you get a FAIL then you know where the issue is. Should you not even get into BIOS, some motherboards have BEEP tones that will indicate you via a tone where the issue is. Some of the Top of the line Mobos have Blinking lights inside of the Mobo doing the same as the beep tones.
I hope this helped
Posted on May 26, 2011
  • 6,771 Answers
The main processor ic, located under the cooling fan, It is the heart of the motherboard, directs all functions in the system.
If the oil pump goes out will it lock up the motor until changed
It will not lick up anything usually, but you must not drive an engine without oil pressure! You will destroy the whole thing.
Dec 14, 2016 | Cars & Trucks
Come on screen but at that time when I press the menu all menu function come on screen but pc display not come. I change display cable & video board also but problem not solve.So, Pls. guide me. Thanks.
If again again display problem create then i suggest you change mother board and purchase own device supported mother board. If change mother board then display problem solved, but one step you change RAM may be your RAM device week and damage. So you first of all change RAM then finally change motherboard.
Thanks...
Oct 09, 2013 | LG 700M 17" CRT Monitor
Installed win 7 lost real tec sound. No drivers work. also can not connect to network printer. sound is important now. have syntax sv266a mother board. No sound board it is in the mother board. I have...
Which operating system were you using earlier?
Try downloading the drivers for that version.
Then right click on those drivers and click on "Troubleshoot Compatibility"
Then install it in the old operating system mode.
Feb 27, 2011 | Syntax SV266A SKA KT266A Motherboard
I have the charger showing the light, however the laptop is not getting started( the battery has drained totally). Is it time to get a new battery or potentially some other problem ?
Other problem. For confirmation remove the battery & insert the power cable. You will face the same problem. 2 type of problem may occur. 1. Adapter damage. or 2. Mother board power supply connector damaged.
Aug 16, 2010 | Acer Aspire 4720 Notebook
My laptop video card damage totally some repair shop said their is no chance to repair or replace.the whole motherboard must be replace.tnx.
well you have to buy a new mother board.because unlike like the desktop the VGA card is built on the motherboard so you have to change the whole board.
Jul 12, 2010 | Computers & Internet
I need total mother board drivers for acer mcp615smam & also product model for the same mother board.
http://support.acer-euro.com/drivers/notebook/tm_6292.html
this is teh model for this mo bo ..and the drivers should be there just select what you use ..and download ..
dont forget to rate me ...Thanx!
May 28, 2010 | Computers & Internet
The refridgerator has stopped working entirely..2 weeks ago the water stopped working, now only the light works
On your model that is an indication that the mother control board is defective. Unplug and remove the panel on the rear of the refrigerator tat covers the mother board. Take it out far enough to examine both sides for burn marks on both signs or heat damage. Let me know what you find, Thanks, Sea Breeze
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Mother board drivers Modle no : k19 pdc T2060 sl no :3074AX382857 S FROM WHERE CAN I DOWN LOAD total mother board drivers
yes you can easily download from this website
http://www.drivers-software-download.org/tag/hcl-notebook-k19-pdc-t2060
Apr 22, 2009 | Computers & Internet
UNRELIABLE SERVICE FROM TOSHIBA
have another way you can even get the files you have on your laptop, first> remove the hdd / Hard Drive from laptop, 2nd >you buy a mobile External Storage for the laptop hdd, you must spend big this is cheap not only matches the mother board too expensive.hopefully it helped a lot to you..good Luck
Jan 02, 2009 | Toshiba Satellite A135-S4527 Notebook
System will not power up
Have you replaced the cmos battery(disc shaed flat 3V CR2032), although there could be more sinister problems than this as the mobo or processor may be damaged.
Feb 12, 2007 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
139 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
