Question about Apple iPhone 3G Black Smartphone
My 8GB Iphone randomly goes to black screen with silver Apple logo during use then takes anywhere from 5 to 30 minutes to reboot or something. This happens quite often now no matter what the phone is being used for. When the phone goes to this screen nothing can be done. It will not turn off or back on. This makes the phone pretty much useless and unreliable. This started 5 days after my warranty ran out :(
    Sergeant:
  • 212 Answers
Well, it seems to me it's more likely to be a problem with the hardware of your phone. Most likely you need to take it to apple for repair or replacement.
A couple of things you can try tho....are first, to do a restore on your iPhone...if it is not a hardware problem, it could be the iPhone software itself. Do a restore, but I would try not restoring from a back up. Get the latest version of the iPhone software and restore the phone from scratch, and then sync your library.
Another thing it might be, could be the battery. There are lots of instructions online about how to change the battery, but it all depends on how brave you are when it comes to ripping apart your iPhone.
I think you may be a bit stuck and may have to take it to Apple for repair.
Good Luck
Posted on May 26, 2011
Can't get any other headphone or any thing to work in my iPhone 3gs
Do a hard reboot on your iPhone...
- Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously.
- Continue holding both buttons until the iPhone shuts off and begins to restart. This will take anywhere from 15-60 seconds.
- You may let go when you see the silver Apple logo. You have now completed the hard reset successfully.
- Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen. This is normal.
Oct 16, 2012 | Cell Phones
My iphone 3Gs is not starting up and is stuck on apple logo. Please help
Do a hard reset.
  1. Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously.
  2. Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart.
  3. You may let go when you see the silver Apple logo.
  4. You have completed a hard reset successfully.
  5. Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen. This is normal.
If this does not work, put into recovery mode and restore from itunes.
Step One
Open iTunes and connect the iPhone to your Mac.
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
As soon as the screen goes black release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
Feb 22, 2011 | Apple iPhone 3G
Iphone frozen between white and black screens - not rebooting
The only option is to try another restore. If that still won't work you need to contact apple.
Jan 06, 2010 | Apple iPhone Smartphone
MY IPHONE IS FROZEN ON THE APPLE LOGO SCREEN
You need to a fresh restore of the iPhone. Hold down the home and power buttons together until the screen goes black. Then while the screen is still black, plug it into your computer WHILE holding down the home button.
At this point iTunes should detect your iPhone and tell you that you need to do a restore.
Hope this helps!
Please rate me!
Jul 09, 2009 | Apple iPhone Smartphone
Iphone only see apple logo and itunes logo in a dark screen after
If it got wet, you can bring it to any Apple Store. Nine times out of ten they will replace it for $150 to $200 dollars. Unless they determine it is a manufacturers defect and you are still under warranty, then you want have to pay anything. they will usually just replace it for you.
Otherwise, you may have to pay up to $200 for a replacement.
Hope this helps...Let me know...
enov8
Mar 07, 2009 | Apple iPhone Smartphone
IPhone 2G hangs at "slide to unlock" - restore not helping
2g solution
3g solution
if it still gives you problems then you have a hardware issue, apple won't touch a jailbroken iphone so hopfully you have the apple care protection. Restore it to factory settings and try to take it in for service.
Feb 04, 2009 | Apple iPhone Smartphone
its not a hardware problem brothe as i am also facing same problem...actually it all happen with jailbreaked iphone...ad i'hv checked its deep root directory there an application called "lockdown" is the main cause of that...nd still there is no crack of that.....
two days back i unlocked my iphone 2g it was working properly before that i was facing the same issue as you are facing....but now again it went to the same problem....
i hav a temp solution of that...
use blackra1n u can find it from blackra1n.com
nd for few seconds slide to unlock will work
or u can use it by connecting it with ur itunes ...connect usb wire nd slide it again nd again...u can unlock it..bue its just temp
Feb 04, 2009 | Computers & Internet
I have an iphone that does this at times too! I have to reboot it periodicly, seems more often when I use it a lot. I have found several issues with winterboard and plugins for it to cause some of my problems. might try changing your screen to normal and see if it still acts this way.
Dec 20, 2008 | Apple iPhone Smartphone
The iphone 8GB Non 3G Touch screen will not work after the phone
Reset the iPhone by holding the sleep/wake button at the top right of the device and the home button at the bottom center of the face at the same time. Hold them both until you see the screen go black and the white Apple logo appear. When this happens, you can let go - the iPhone is rebooting.
Dec 18, 2008 | Apple iPhone Smartphone
Apple iPhone 3G Black  Smartphone Logo
200 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
