Question about Garden
What kind of oil do i need for my stihl grass trimmer
5 Suggested Answers
  • 246 Answers
SOURCE: no user manual
Hello:
Most 2 Cycle Engines use a 32:1 or 40:1 Fuel Mix Ratio.
The Newer 2 Cycle Engines use a 40:1 or 50:1 Fuel Ratio.
For Better Performance and to be sure you have Plenty of Oil to the Engines Internal Components, I Suggest (and I Use) a 32:1 Ratio in All my Equipment except for Post Hole Diggers.
Post Hole Diggers Use a 25:1 Fuel Ratio.
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
dontbother10
  • 2220 Answers
SOURCE: what is the correct ratio gas to oil for my stihl fs 66 trimmer
Use a quality 2 cycle oil and mix it to the oil manufacturer's recommended ratio. Today it is usually 50:1.
Fuel in the USA contains ethanol; try to use up your mix in a month or less. HTH
Lou
Posted on Sep 07, 2009
nova2nv
  • 197 Answers
SOURCE: Ref: Stihl FS46 string trimmer. Broken Flex shaft.
Remove orange sheild,remove single screw holding head in shaft then grab head with pliers and twist side to side until complete head is free.You should then be able to grab part of shaft.On power head loosen screws {about one turn each} that hold two white case halves near trigger,I think there are four,then there is a single torx screw on the bottom of lower case half in the middle that must be taken out to allow tube to be removed.Romove flexshaft from top.Check 4 plastic burnt to flexshaft,if there is you must replace tube liner as well,usally around bent part of tube the liner will go bad.
Posted on Nov 28, 2009
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
Posted on May 24, 2010
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
Where is the model number on a stihl grass trimmer?
depending on age, either on the recoil housing, the engine cover or a sticker on the shaft
Apr 21, 2015 | Stihl Garden
Hi, i am Florencio Valiente looking for grass cutter spare parts please help me to it. STIHL FS55C.. unit cranck shaft assembly, 1 set spiral gear asssembly pls. advice..
New Stihl are sold by the local dealers only per Stihl policy.
I couldn't parts labeled Spiral gear so that maybe just a description problem here.
As for the crankshaft you will need know which version you have. Affects ignition timing.
Feb 08, 2015 | Stihl Garden
How to check exhaust on a stihl grass trimmer fs45c
if your problem is it will idle but not rev up then clean your screen in the muffler and check muffler for carbon
Oct 04, 2014 | Stihl Air Filter 4134 141 0300 for FS120 /...
What is the gas oil ratio for stihl grass trimer
50:1 100ml of oil in 5L of petrol
Aug 05, 2014 | Stihl Garden
My stihl grass trimmer filter came off gas line in gas tank and I can not retrieve gas line.
Usa a bent coat hanger or wire to hook the fuel line out the top of the filler cap. It will stretch enough for you to push the filter back on.
Apr 12, 2013 | Stihl Garden
Stihl strimmer engine runs but wont cut grass the head wont turn what cuts grass
First take the head off and look for grass, weeds and string wound up in there. A lot of times that's the problem.
Next, with the head off and the switch in the off position, pull it over a few times and see if the shaft spins. If not, could be a broken shaft or a bad clutch.
Apr 04, 2010 | Oregon Scientific Complete Carburetor for...
Stihl carb
Try this link. It has the carby settings on page 26 & 27 of the Stihl FS 45 manual.
http://www.mccoyslawn.com/parts-manuals/Stihl/FS45_46_Manual.pdf
Apr 17, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
