I have just installed a new colour and a new black ink cartridge but it will only print in black and white and not colour. Why??
  • 60 Answers
Check your settings under the Printer settings... you might have changed it to BLACK & WHITE only.
Make sure that you have the global settings set so that by default the printer uses BEST Quality depending on model.
Posted on May 26, 2011
How do I change the ink setting from colour to black and white on the control panel after I have removed a colour ink cartridge and replaced it with a black and white cartridge?
I doubt the printer will work. You need to go to properties in the program you are trying to print from to change from color to black and white, but again I doubt the printer will print without both cartridges installed properly.
Oct 02, 2017 | The Office Equipment & Supplies
Printer only prints in black/white. have put new
It could be the print setting on your computer.
If you're using Windows, with your document open, go to File > Properties/Preferences. In the Print Setup tab, make sure to select "Print using all available ink" in the Ink Use section.
On Mac you can select Color in Print Setting in any expanded print dialog.
Sep 01, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Printing in just black and white
Epson,. has it rigged, that you must have ink in all the cartridges.............! Doesnt make a difference, if you are printing black and white ONLY.
You have to replace them.
Good Luck......
Dec 29, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Colour cartridge missing but I only want to print
No you cannot. Each one of your cartridges is smart chipped. When this cartridge registers as empty it acts as an on/off switch thus turning the printer off.'
You need to replace the empty cartridge in order to print.
Go printer settings and check option to print only black.
Jul 30, 2009 | HP Photosmart 3210 Printer
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
Can't print color only black and white
Please check if your Colour Ink Cartridge is not emply. If their's ink in the cartridge then try to service your printer through the Print Preferences. Your Colour Cartridge Nozzels could have been blocked thats why your printer is unable to print in Colour.
In case if both the above doesn't work then check in the Print Preferences that you should not have saved the option of PRINT DOCUMENT IN BLACK ONLY. hope this helps , AJ
May 18, 2009 | Dell 966 All-In-One InkJet Printer
Does not print black
Most likely you have no black cartridge installed or it is empty causing your printer to use the colour cartridge for black. But if your colour cartridge has 1 colour which is less full than the others it causes black to become greenish or sometimes reddish depending on which colour is less. A new cartridge or a black cartridge will solve the problem.
Aug 08, 2008 | HP DeskJet 825c InkJet Printer
I cannot print but i have only the black cartridge but i dont have the yellow cyan ang midget
Most modern printers use some colour when printing Black and therefore will not print if ANY ink cartridge is showing as empty.
Unless your printer has a setting for using Black ink only (this is not the same as printing a black and white document), then you will need to purchase and install the colour cartridges before printing can take place. The good thing about this is that very little colour ink is used when printing black and white documents - so they should last a long time.
Good luck.
May 09, 2008 | Brother Multi-Function Center MFC-240C...
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
jasbo
jasbo
