First check to see that you have enough hydraulic fluid in the resevoir and that the right side hydraulic pump is not leaking....there is the possibility that the lever that controls the right side is slipping on the shaft where it connects to the pump causing this condition...if you have the manual the mower came with ..you need to go to the procedure for bleeding the air out of the pump....if it is not in the manual, you can call a dealer for the instructions or order a service manual....if all the above does not fix the problem... then you may need to get a rebuild kit for the hydraulic pump...these are not too expensive..but they beat buying a new pump as pumps are anywhere from 400-700 dollars
Any idea where to find the hydraulic fluid resevoir on the Z5426? My local dealer doesn't even know how to check the hydraulic fluid, and I can't find anything that looks promising.
Thanks.
sealed resevoir cannot check. Check the hub lug on the axel. It might be loose and the splines are not catching
