Question about Cisco Aironet 1310 Outdoor Access Point/Bridge - Radio access point - 802.11b 802.11g (AIR-BR1310G-E-K9-R) 802.11b/g
How to reset factory default for AIR-BR1310G-E-K9
3 Suggested Answers
SOURCE: I Need IP Default air-lap1141n-a-k9
Taken from learningnet.cisco.com
Also be sure you statically set your computer's IP to 10.0.0.2 with a default gateway of 10.0.0.1 (10.0.0.1 is the default IP that the AP assigns itself when you boot it into recovery/flash mode), of course you can change all of this via the command line, however, it may just be easier to leave them defaulted.
Posted on Feb 22, 2011
  • 11 Answers
SOURCE: I cannot find the default ip address for Cisco
Hi, The Access Point does NOT have a default ip address
below is quick setup guide to the Access Point
http://www.cisco.com/en/US/docs/wireless/access_point/1240/quick/guide/ap1240qs.html#wp41082
Posted on Jun 01, 2011
Testimonial: "thanks a lot,i rili apreci8 it.ciao!"
Can get router to work
The Cisco Aironet 1200 access point provides secure wireless connection to your network. Cisco's wireless access design meet the needs of a small to medium size business.
This unit provides secure network access for laptops or Wi-Fi capable portable devices, which you upgrade at any time as your business grows.
A beneficial feature of the Cisco Aironet 1200 is its ability for the administrator to reset the access point remotely.
This resetting process works through your internet browser.
Log on to the System Configuration page by entering your Cisco Airnet 1200 IP address in your browsers web address text box.
Enter your user and password information from the pop up menu.
Click on the "Setup" button from the summary status page.
Select the "Cisco Services" setup option and click on "Manage System Configuration."
Click on "Reset All System Factory Defaults" to reset the router.
The Cisco Aironet 1200 will be restored to factory defaults.
http://www.cisco.com/en/US/products/hw/wireless/ps430/index.htmlCisco Aironet 1200 Series
Configaration Cisco Aironet 1200 Serieshttp://www.cisco.com/en/US/docs/wireless/access_point/1200/vxworks/configuration/guide/bkscgc10.html - wp1016665
May 07, 2014 | Linksys Cisco Aironet 1200 Wireless Access...
How to reset 9971 cisco phone to factory default
You can do that by pressing the Applications button on the phone and choosing Administrator Settings. From the Administrator Settings menu, unlock phone options, then choose Reset Settings > All Settings.
I hope this helped you.
Oct 06, 2011 | Cisco Unified IP Phone 9971-Charcoal...
Hello all, i need to reset password on Cisco wireless LAN controller NME-AIR-WLC8-K9 module installed on router 3800 thanks a lot
Press a restart button at the back of your router, and hold it like that for 20 seconds.
That will reset all your settings!
Good luck. I hope this will help You!
Jul 31, 2011 | Cisco Wireless LAN Controller Enhanced...
I need to reset the password for Wireless LAN controller NME-AIR-WLC8-K9 module installed on Router 3800
Press a restart button at the back of your router, and hold it like that for 20 seconds!
Good luck! I hope this will help you!
I cannot find the default ip address for Cisco AIR-AP1242AG-E-K9. can anyone help?
May 30, 2011 | Cisco Aironet 1242AG (AIR-AP1242AG-E-K9)...
How to reset to factory default?
Hi nbergma,
To Factory reset your router you need to locate the Reset Button at the back of the router. The Reset Button is the small hole at the back and you need a Pen or a Paperclip to press it. Press and hold the reset button for 10-15 seconds. Make sure that the router is on when you reset it.
Thanks for using Fixya.
Jan 28, 2011 | Cisco (AIR-BR1310G-A-K9) 802.11g/b
Reset my Cisco AIR-AP1242AG-N-K9 but still can't access the control panel using a console calbe and laptop. Using Cisco Cisco as user name and password. Note when typing the password nothing appears in...
Hmmm..., I assume you are using Windows..... Try just going to the Network, see if you router shows up if so.... Click on it... It should ask for a pin type in the pin that usually can be found on the bottom of your router... If not reset to factory defaults and in your broswer type in your IP address, do not use autoconfiguration.... On all Linksys routers the default username is admin (with the password left empty) from there you can set your password and configure your router for use.... Hope this helps ;)
Jan 05, 2011 | Cisco Aironet® 1242AG (AIR-AP1242AG-N-K9)...
How do i reset a 1231 to factory defaults
Unplug the AP then hold in the mode button (use a paper clip or pen tip). While still holding the button down plug the device back in and wait for the light(s) to go steady red. If your AP has a console port you should be good to go..if you have to telnet or use the GUI then the set your computer to 10.0.0.X and create an Adhoc network to gain access to the CLI/GUI.
Jul 26, 2010 | Cisco 2106 (AIR-WLC2106-K9)
How to reset c2106 to factory defaults?
do you have a little button behind it ?if you do tap it for 20 seconds.
Feb 23, 2010 | Cisco 2106 (AIR-WLC2106-K9)
Wet54g will propperly communicate to a cisco 1310
make sure you switch anything that says 'proprietary', or is just not standard 54g with the wireless settings.
Some manufacturers will put in auto-discovery services that only that same manufacturer of wireless access point will understand, this can sometimes cause problems for bridge communication.
Mar 20, 2009 | Linksys Wireless-G WET54G 802.11g/b...
Cisco Aironet 1310 Outdoor Access Point/Bridge - Radio access point - 802.11b 802.11g (AIR-BR1310G-E-K9-R) 802.11b/g Logo
980 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
