Question about Westinghouse Refrigerators
Integrated top door hinge on fridge has dropped causing seals on actual fridge door not to connect properly needs new hinge but having difficulty in finding correct one the serial no inside reads st9140 plus 770886600271100 can you help pls
4 Suggested Answers
iwillfixforu
  • 619 Answers
SOURCE: Fridge Door seems to have dropped
The cam risers at the bottom hinge have gone bad. Get the model number form the fresh food section and you will be able to order new ones. Not expensive to repair.
Posted on May 16, 2010
SOURCE: The top hinge of my neff integrated fridge freezer has broken.
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
Posted on Jun 12, 2010
  • 122 Answers
SOURCE: I have a ten cubic
Sounds like the cabinet isn't square. sometimes you can loosen the top hinge and adjust the door. Otherwise you can try putting another washer under the bottom hinge.
Posted on Mar 21, 2011
The top door is rusted out where the hinge fits. I want to patch it up to use in my shop. I tryed mounting some flat type door hinges but it don't work well
without knowing the refrigerator its a tough one, but refrigerator hinges are designed to allow the magnetic door seal to seal properly, flat door hinges typically not a good choice for this application
  • Either pop rivet some new metal plate to replace the rusted area and use existing hinge
  • try get replacement door from used refrigerator or refrigerator recycle place.
  • buy new/used fridge from kijiji :)
Aug 24, 2011 | Kenmore Top Freezer Refrigerator
How to remove doors of a whirlpool 6vmw47 top mount fridge/freezer
Hello Hicherringto,
I understand that you would like instructions on how to remove the doors on your fridge. Most common on top mount freezers/fridges you need to start at the top and work your way down.
1. Locate the freezer hinge top part where the door swings.
2. Remove the plastic cover over the henge. (top of the box if covered)
3. Remove the screws holding the henge in place.
4. Lift up on the henge
5. Open the freezer door and lift up (the door should lift off the bottom pin)
6. Open the Fridge door and remove the screws from the hinge that the freezer door sat on
7. Remove the hinge from the fridge door by lifting up
8. Open and lift up on the fridge door
9.Reinstall in reverse
That is the easiest way to remove the doors on a top mount freezer fridge. Note that when you reinstall the doors you will have to adjust the hinges so that the seals seal properly. The hinges have enough of a grove that you use them to adjust the doors.
Thank you for choosing FIxYa.com
Justin
Apr 16, 2011 | Whirlpool Refrigerators
I have an Inglis fridge and when door is closed there is about a1/8 of a inch space between the seal at the top and fridge . Bottom seals properly
That can be caused by hardening of the bottom seal due to ice build up in the seal or the door hinges need adjusting by loosening the lower hinge and pulling it out slightly to compensate for the door seal.
Mar 05, 2011 | Microwave Ovens
The refrigerator door does not close properly to make a seal. i have to lift the door up by the handle and close it to get it to seal and turn off the inside light. the door has dropped significantly. i...
There should be a hinge plate on the top outside of fridge and at the bottom. Loosen these then close the door and make sure it is seated properly. with door closed tighten top hinge mount the open door if needed to tighten inside mount. May need to be done a couple of times to get correct fit
Jan 10, 2011 | Hotpoint Refrigerators
I have a full length fridge and the door seems to have dropped about 1/4", causing the door to bind at the hinge and catch against the adjoining unit on the closing side. What do I adjust and how...
sounds like lower hinge loose or bent down or plastic washer wore out remove top hinge and either move bottom hinge up or shim with washer to raise door
Feb 03, 2018 | Liebherr European Right Hinge Fully...
Door on my integrated Bosch fridge keeps opening
Seals rarely fail most likely needs hinges replaced,parts quite cheap
Jun 16, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
May 02, 2008 | Refrigerators
Refrigerators Logo
37 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
