Question about Amana Refrigerators
A few weeks ago we noticed that the freezer was not keeping the foods frozen, the back part of the freezer would form ice and cover up the vents we scraped the ice off and an hour later it was all back clogging the vents. The icemaker does not work as well. What can I do?
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on May 26, 2011
Refrigerator is warm. found ice packed in vents on frig side cleaned them out but now we noticed that the vents in the back of freezer are also packed with frozen ice build up. could this be the reason for...
That ice is the reason that the freezer is working but the refrigerator is not cooling. That ice is
blocking the vent that allows cool air to leave the freezer section andfall down into the refrigerator
section.
The fix is free: defrost the frig - pull the plug, and let that icce melt out of there, clean up the
wet mess, and turn the frig back on - problem solved.
Keep the vent area free of ice (and other blockages, like frozen peas covering over the vent), and
you'll keep the problem from recurring.
Aug 08, 2011 | Refrigerators
One year old Maytag refrigerator with bottom freezer. We noticed recently that water accumulates and freezes at the bottom of the freezer under the basket. We don't notice it then when there is enough...
The drain to the bottom is plugged. you will need to completely defrost the unit. The way I do this is to take all the frozen food out and either put into a different freezer or pack all the frozen food real tight in a cooler then use a hair dryer (under constant supervision) to melt all the ice in the bottom. use towels to soak up all the water. after all the ice is melted you should be able to see the drain. this is where the melted ice drains when the unit goes into the defrost cycle. I have used some small amount of hot tap water to clear the drain and once in a while you need to actually push something thru the tube(compressed air or flexable wire) to clear out a blockage (paper, small piece of food or chunk of ice).. Be extra carefull not to crack the plastic with anything sharp or by using to much force. Once the tap water goes down into the very bottom (thru the drain tube into the catch pan) then the ice won't form as the defrost cycle will put the water clear down to the catch pan. sometimes even a scumy mold build up will block the drain. Get the drain as clean as possible and you may need to keep an eye on it so it doesn't become blocked again. After you clear the drain close the freezer and let it cool down before you put the frozen food back into the freezer.
May 01, 2011 | Maytag Refrigerators
We have a GE side-by-side refrigerator (GSS23QGTA); it's about 6 or 7 years old and has been working just fine until about a month ago when we noticed that the freezer was not freezing food. The temp had...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Feb 16, 2011 | Refrigerators
Freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 | Freezers
Water leaking from top to bottom
Refrigerators typically have vents for COLD freezer air to travel to the refrigerator side. Make sure you do not have these blocked with frozen foods, or ice. A good defrost of the freezer may be in order. (I just went through this one week ago).
If the cold air does not travel down to the fridge to keep it above dewpoint, moisture begins to form quickly.
May 19, 2009 | Refrigerators
Freezer Does Not Stay Frozen
one of the hardest things to diagnous is food defrosting in the freezer. i found out the hard way about 35 years ago, but not until i banged my head against the wall a few times. the problem was the customer didn't have enough food in the freezer as she was a weekender.frozen food needs frozen food to keep the food frozen confused? so was i . every time your refrigerator goes into defrost( usually every 8 hours) a heating coil comes on in the back of the freezer. if the freezer is not full enough this heater can raise the temperature in the freezer to 40 degrees which will soften the food and melt the ice considering the time it takesto refreeze the food. i never forgot that service in fact i can see it in my head right now.. try this cure first let me know
Feb 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not keeping things frozen
Hi Jody,
The only thing you give me that would allow me to solve this issue, is based on the fact that the freezer is getting warmer, and fresh food section is staying cold. So, knowing nothing more than that, I must sadly say that you need a new refrigerator to solve this issue 100%, as it sounds like you have a failing compressor, or a slow leak in the sealed system. Both scenarios are terminal.
Thank you for contacting me at Fixya.com
Dave E. (Illeagle)
Jun 12, 2008 | Freezers
GE TPX24BPBGBB fresh food section won't cool
Have you noticed any ice built up on the rear freezer wall? it is very likely that you have a defrost problem situation,IE: Heater,Defrost Thermostat,Defrost Timer any failure in these components will cause an icing problem and therefore you will not get sufficient air flow to the Food Compartment
Sep 20, 2007 | Refrigerators
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Refrigerators Logo
51 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
