Question about EliteGroup P4VMM2 Motherboard
Like cmos battery problem.... checking nvram
I taked battery changed but nothing happen also i trying to clear my cmos battery but when i changed the jumper in clear mode my unit can't reboot but when i jumper it back to the normal mode my unit can boot again.... pls help me what will i do thanks
  • 781 Answers
That is what you are supposed to do move jumper 30 seconds and replace back to original
your BIOS should be set to default check that you have correct ram inserted into M/board
Posted on Aug 17, 2008
How to remove bios password
hi lata.
you can try this.
  1. Remove the computer cover.
  2. Locate the 2-pin password connector (PSWD) on the system board.
  3. Remove the 2-pin jumper plug and set the jumper plug aside.
  4. Replace the computer cover.
  5. Connect your keyboard and mouse, then connect your computer and monitor to electrical outlets and turn them on.
More items...
How to Perform a BIOS or CMOS Reset and/or Clear the NVRAM on ...
or go to this link.
How to remove bios password Google Search
Nov 06, 2017 | Computers & Internet
Password hack
While removing the onboard battery and disconnecting all power for 5 minutes may clear the bios, some passwords are written into NvRam (non volitile Ram). This may require you to move some jumpers. Try this.
It may be necessary, on occasion, to clear the CMOS settings. When the CMOS is cleared, all information stored in the CMOS is replaced by default data, which means that all of the configuration information, such as hard drive types and I/O port setup, is cleared, including the password. Use the following procedure to clear CMOS:
  1. Power down the computer.
  2. Remove the left cover of the computer.
  3. Wearing an anti-static wristband grounded to the chassis, remove the jumper from pins 1 - 2 of the Clear CMOS jumper block (JP15) and install it on pins 2 - 3.
  4. Remove the jumper from pins 2 - 3 of the Clear CMOS jumper block (JP15) and install it on pins 1 - 2. (NOTE: Some earlier systems will power up as soon as the jumper is removed from pins 1-2. Later versions of the BIOS change this, 6.00.10 or later.)
  5. Reinstall the cover and power up the computer.
  6. Run the BIOS Setup program to reconfigure the system.
Nov 25, 2013 | Gateway Computers & Internet
No Nvram Found
NVRAM should be your BIOS, if that's not found you've got something wrong with your motherboard. I don't think it's a dead CMOS battery but you could try changing it, dead CMOS batteries usually say bad checksum.
edit: try removing any hardware you don't need for the computer to boot then if it works, add them back one by one __________________
Apr 05, 2012 | Dell 5210n Laser Printer
How to reset bios password on hp ProLiant 360 g5
power off server,switch on SW6 of the Maintainance switch.Boot server.Switch of the server and put back the SW6 to OFF Position.Then switch on the server.Your NVRAM(CMOS) is cleared
Nov 17, 2011 | HP ProLiant DL360 G5 Server
My PC desktop is in power saving mode, how can i put into normal mode?
This is what i do whenever someone asks me to remove their PC from power saving mode.
Follow there
Try clearing the NVRAM as follows:
-Turn off the computer
-Disconnect the monitor.
-Unplug the computer.
-Take out the video card.
-Remove the CMOS battery for a couple of minutes.
-Insert the battery.
-Connect the video card and monitor.
-Turn on computer.
Apr 05, 2011 | E-Machines eMachines Desktop PC
When I power it up nothing comes up on the monitor??
1. check the RAM is seated
2. Try any other RAM
3. still the same problem check the video or graphics card , if any
4. if no graphics card and problem stiil changing it clear your CMOS by removing battery
5. if its new system then, remove battery, then take a small wire piece and short the positive and negative of the battery socket, then only CMOS is cleared
6. still problem , check the processor heat sink
7. still problem then suggesting checking motherboard and processor
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 11, 2010 | Gateway M275 Tablet PC
What does the bttery control? Can I remove it for 5 seconds,then replace it and solve the ITHR checkpoint problem ?
if you are referring to the round battery on the motherboard, it controls the cmos settings remove this and your PC will not boot. yet clearing your cmos may help. look for the lil jumpers usually located near that battery and change them to reset, power on let boot then power down. then place them in the original slot.
Aug 10, 2009 | Dell Dimension 3100 PC Desktop
Optiplex G620 has "munged" BIOS Admin password. Children plaed and saved. Any idea how to clear it ?
Hi there.
Try clearing the cmos fdbf23f.jpg. move the plastic jumper the alternative position, power the pc up (Nothing will happen if you have it correct, then put it back in its original position and try to boot the machine again, password should be removed.
Good luck and thanks for using Fixya!!
Feb 13, 2009 | Dell OptiPlex GX620 PC Desktop
HP desktop computer will not load...
what os you are loading?
did you purchased it with bundled os/softwares?
Apr 01, 2008 | Computers & Internet
Hi, This message "Checking NVRam" is part of the BIOS/CMOS POST even before Windows loads up. Offhand two things you can try: 1. Do a CMOS reset by temporarily moving the jumper near the battery to the opposite pair or by removing the Lithium battery for a couple of minutes or as prescribed by your motherboard's user manual; 2. If #1 is a no go, perhaps you should consider flashing your BIOS. If neither works out, it is possible that you have a hardware/motherboard problem and would require replacement. Hope this be of some help/idea. Post back with your motherboard brand/model, how things turn up or should you need further information. Good luck and kind regards.
Sep 14, 2007 | Computers & Internet
EliteGroup P4VMM2 Motherboard Logo
121 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
