Question about AEG B4101-4 Electric Single Oven
AEG competence B4101-4 built-in electric oven, the fan is staying on continually even when not in use. Only goes off if the oven is switched off at the mains. Is there a way to fix this problem?
When i bake a chocolate sponge cake it rises well,when cooking the top becomes cracked like dry earth and when switched off it comes down about a third. with my previous oven baking thesame recipee for 30 years i never had a problem- please advise the reason for this problem
Posted on Jun 12, 2011
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
May 04, 2010 | AEG B1180-4 Electric Single Oven
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Feb 05, 2010 | AEG Ovens
I have a Competence B1180, it cuts out after irregular periods of time, although sometimes it may even complete a cooking cycle, if turned off for 10-15min it will re-start, but invariably cuts out again...
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
Mar 01, 2009 | AEG B1180-4 Electric Single Oven
AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 29, 2008 | AEG D5701-4 Electric Double Oven
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
AEG Competence Double Fan Oven Fault
Sounds like oven element is faulty, disconnect it and try again, if it does not trip, then it is definately the element..
It is easy to replace.
Plz leave feedback.
Sep 22, 2008 | AEG B2100-4 Electric Single Oven
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
AEG B4101-4 Electric Single Oven Logo
279 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
