I have a Kenmore Elite smartwash steamcare Quiet Pack 9. It starts the cycle but often continues until the need to drain an spin. At that time it shoew a "Sub" code and right after that come the fatal F21 code. Last week it was able to complete the express wash cycle only, but now it can't complete any, not even the Drain and Spin cycle only. I really need help!!!!
  • mercedes_245 May 27, 2011
    This service is great!!! Solution was oferred in a very detailed maner, including photos and video. It worked great! Thank you FIxYa for a great option
    Thank you very much! Your help was more than expected!!
  • Washing Mach... Master
  • 8,220 Answers
You should do the old filter cleanout. Remove the base panel and get the junk out of the pump filter.
How to video
Posted on May 26, 2011
Kenmore elite smartwash quiet pak 9 he4t won't engage when start button pressed.
The start button operation could be erratic, indicating the need for replacement.
Dec 12, 2016 | Kenmore Washing Machines
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Dec 22, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore elite smartwash quiet pak 9 he4t the washer starts filing water when the washer is turned off.
This is symptomatic of a malfunctioning water control valve- not closing fully- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 19, 2011 | Kenmore Elite 45986 Front Load Washer
My HE3 kenmore elite quiet pak2 will not empty out water and spin
This due to the drain pump either being clogged or having a broken pump rotor. You can access the pump to check this by removing the bottom front panel by removing the 3 screws under the panel. You will need some towels bacause you will have A LOT of water come rushing out when you unscrew the drain pump cleanout. If this cleanout is clogged, remove the obstruction and test the washer, if there is no clogg you will need a new drain pump, this part can be ordered at, http://www.reliableparts.com/ by using your model number to lacate the pump. It is very easy to replace, just be sure to disconnect the power to the washer first =)
Please rate mt solution if it was helpful to you.
Thanks, Repairman45
Dec 15, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite is now LOUD during spin cycle
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 11, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
He4t kenmore elite smartwash quietpak9. keeps flashing F2?
"F02" is a Long Drain error. This is an indication that there's an obstruction somewhere in the drainage system. Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the bottom front edge of the lower toe panel directly below the door. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Mar 02, 2010 | Washing Machines
I have a kenmore elite smartwash quiet pak9 he4t water wont drain on the final rinse cycle. The only error message i get a the letter F. Does anyone know what that means?
Dont know the code but i would imagine it means the water has not emptied in the max time preprogrammed,either the drain is slow or blocked or drain pump is faulty
May 04, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite smartwash quiet pak 9 he 4t seems to be off
have you tried lower spin speeds? I found with heavy items such as towels and jeans it is best to lower the spin speed. also washing like heavy items on a certain wash cycle is best - i.e. towels on bluky/bedding.
hope that helps.
Apr 08, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
263 people viewed this question
Top Washing Machines Experts
