Question about Canon imageRUNNER 2020i Black and White Copier
We are not able to use scan to mail feature in canon 2020i. It demands some password which we do not know what to do. Can some one advice us a solution.
    Sergeant:
  • 372 Answers
Reset all the data inthe service mode by pressing adittional function 28 additional fuction . goto the clear and then press clear all
that it no more passwords but do enter the ip again
Posted on May 26, 2011
Default password for canon ir 2020?
  1. Enter the IP Address of the printer into a web browser.
  2. Enter the System ID. The default ID is 7654321.
  3. Enter the password. The default password is 7654321.
Jul 23, 2014 | Canon iR 2020i Laser Printer
I have a canon imagerunner 2020I copier with a
this message is 90% from the second tray.try to close the small door of the 2nd cassette forcefully.if it does not work u can disconnect the second tray by unplugging the wire from the engine board on the back side of the machine by removing the back cover.it will be a yellow p/j in the middle of the board.u can easily trace it as it goes down to the 2nd tray.
Jul 13, 2011 | Canon ImageRunner 2020i Copier
Hi How do I get my Canon iR2016i to automatically
You need to install a PDF printer driver on yourcomputer first. There are quite a few freeware PDF writer programs on theInternet you can download one such as CutePDF.
Scan your document then click on File - Print and select the PDF writer as theprinter device. Then name and save the PDF file. To download Cutepdf PDF printer driver (freeware) click onthis link :- http://www.cutepdf.com/
Jun 29, 2011 | Canon iR 2020i Laser Printer
Hi, I need help setting up the scanner on my canon 2020i.
Hi, How to set up the scanner on canon 2020i?
By Subbaramaiah, Kurnool
Mar 28, 2011 | Canon imageRUNNER 2020i Black and White...
Our office has a Cannon Image Runner 2020i and we are having issues with the scanner. Before today, it was scanning perfectly and sending the documents directly to our email. However, today, we can scan a...
Try to stop the copier and restart it, maybe it's something stuck in memory
Click the button stanbay more than three seconds and you will have a shutdown button on the display. After shutdown, remove the power cord, leave it a few seconds and put it back on, start the copier button, let me know if the problem persists
Dec 16, 2010 | Canon imageRUNNER 2020i Black and White...
Canon imageRUNNER 2020i left door paper jam error.how to reset Tried to clean everthying,and there is nor paper jam.
I have a Canon ImageRunner I seem to have a paper jam. The red light is coming on showing the jam in the upper section of the machine but I have cleared all the sections I know to clear. I have turned the machine off and back on the jam light is still on. I can't find the Manuel to see what the problem is. What should I do?
Nov 29, 2010 | Canon imageRUNNER 2020i Black and White...
I have a Cannon 2020i Image Runner, we had thunder storms over the weekend with power interruptions. Came in today and copier will not power on. I have confirmed the receptacle is live, is there a...
You need to remove the back cover and on power supply pcb there must be fuse. I belive glass fuse 5X20mm, not sure for how much A.
For service manual and board circuit send me mail on emma.servis@gmail.com
Sep 07, 2010 | Canon ImageRunner 2020i Copier
Canon Imagerunner 2020i scan to pc- set default send to address
you need to store that location in the address book, its under additional functions, once there you have to enter info for scan location
Apr 11, 2009 | Canon imageRUNNER 2020i Black and White...
How do i activate scan to email on xerox 7132
The Scan to E-mail feature provides the ability to scan and send a document as an e-mail attachment.
NOTE: The Scan to E-mail Kit is required to enable the Scan to E-mail feature. The kit contains a License Agreement, installation instructions, and a password.
You must be a System Administrator to perform this solution.
To enable the Scan to E-mail feature:
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm]. The System Administrator Menu screen will be displayed.
  5. Select [System Settings] twice. The System Settings screen will be displayed.
  6. Select [Common Settings]. The Common Settings screen will be displayed.
  7. Select [Maintenance / Diagnostics]. The Maintenance / Diagnostics screen will be displayed.
  8. Select [Software Options].
  9. Select [Keyboard].
  10. Enter the password contained in the Scan to E-mail Kit using the keyboard on the Touch Screen, and then select [Save].
  11. Select [Reboot]. The machine will automatically power OFF, and then power ON.
  12. Enable the Scan to E-mail port settings. See the Related Items below. After the port settings have been enabled, the E-mail option will be displayed on the Touch Screen.
Jul 30, 2008 | Xerox Office Equipment & Supplies
Canon imageRUNNER 2020i Black and White Copier Logo
126 people viewed this question
old marine
old marine
