Question about Epson Office Equipment & Supplies
Says paper jam but no paper in machine but still cannot clear error message to continue printing
  • 92 Answers
If the paper is jammed, remove it first. then press the "OK" button to resume the printing session..
Posted on May 26, 2011
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
DCP-J125 Uable to print (36)
The message Unable to Print (followed by a two character code) will appear on the display for one of the following reasons:
- Dirty encoder strip
- Foreign object, such as a paper clip or ripped piece of paper, stuck in the machine
- Mechanical malfunction
The most common cause of the issue is dirt on the encoder strip. Clean the encoder strip by doing the following:
CLEAN THE ENCODER STRIP
NOTE: The images shown below are from the representative product. The customer's model may look different from the picture.
1. Locate a lint free cloth such as a T-shirt, DRY eye glass cleaner cloth, DRY monitor cloth or wash cloth.
DO NOT USE ANY TYPE OF PAPER PRODUCTS (EX: paper towel, tissue paper, napkin, filter, news paper etc.) This will help ensure the dirt is removed from the encoder strip.
CHECK FOR FOREIGN OBJECTS & PAPER JAMS
2. After thoroughly cleaning the encoder strip, look inside the machine and in the two corners for jammed paper or foreign objects and remove them if any are found. Pieces of paper may be jammed under the print head.
If the print head is locked to the right side of the machine, press and hold the STOP/EXIT key for 5 seconds. This will cause the print head to move automatically to the middle of the machine and allow you to look for debris in the right corner.
3. Leave the scanner OPEN and turn the machine around so you are looking at the back of the machine.
4. Open the Jam Clear Cover and look inside the machine for paper. Remove any jammed paper that appears; then close the Jam Clear Cover and turn the machine back around to the front.
5. Gently close the scanner cover and verify the error message cleared from the display.
If you cleaned the encoder strip ONCE and the message continues to appear on the display, clean the encoder strip again. It is common to clean the encoder strip multiple times to resolve the issue.
If you cleaned the encoder strip at least TWICE and the message continues to appear on the display, unplug the machine from the power outlet for 2 seconds and plug it back in to cycle the power.
TEST THE MACHINE
NOTE: After a paper jam has been cleared, the Brother machine may complete a 2 minute cleaning cycle to remove paper dust from the nozzles before printing.
May 01, 2012 | Brother Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
Oct 26, 2010 | Brother Office Equipment & Supplies
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Unable to clean message
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
1.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2. If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine...
Thanks.
Dec 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to initialize
To clear paper jams:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_003.html?reg=us&c=us&lang=en&prod=mfc420cn_us
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 29, 2008 | Brother MFC 420CN All-In-One InkJet...
69 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
