Question about AO Smith 1.5hp Pool Pump Motor 2 Speed Ao Smith Electric for Motor Pool & Spa Pump Bn34
Trying to replace the seal but can't get the impeller out
  • AO Smith Master
  • 1,384 Answers
THE SHAFT " PROTECTOR" ON THESE THREW BOLT MOTOR PUMP IMPELLERS , IS A JOKE. IT RUSTS TO THE SHAFT OF THE MOTOR MAKING IT NEAR TO IMPOSSIBLE TO REMOVE. I HAVE A 75% SUCCESS RATE. I TAKE THE ROTOR OUT OF THE MOTOR AND STICK IT IN THE VISE, THAN I TRY TO GET THE IMPELLER OFF THAT WAY. GOOD THING MOST THE IMPELLERS FOR THESE ARE CHEAP ONLINE. OH AND I CUT OFF THE "SHAFT PROTECTOR" ON NEW IMPELLERS, AND USE NEVER SEIZE .. HEY YOU .. PRIME THAT PUMP WITH WATER AFTER ANY PUMP REPAIR !! NEVR STARVE THE PUMP FOR WATER !!!! .. CLICK ON THE YES IF'N I WAS OF ANY HELP AT ALL ... JAY TOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA...FREE TESTING
Posted on May 26, 2011
I can't get the impeller on to my jacuzzi pump
Check the location of the seal kit to make sure you put it back on the exact way the old one came off.
Is the impeller the exact same shape and size as the original?
Rod
US Parts Center
888-521-6183
May 27, 2012 | Jacuzzi IMPELLER FOR 7LVL 7LR 7
Jacuzzi pump motor leaks at the seal
This means that your pump seals are bad. They are an inexpensive part to replace luckily, but removing the impeller can be tough. There are a number of different Jacuzzi motor/pumps so be sure to get the right seal kit.
Briefly:
The trick is to stop the shaft from spinning while you loosen the impeller. FYI they don't usually come off easily, the older the pump the harder it is to remove the impeller.
On the rear of the motor there is a slot where you can put a flat screw driver into the back of the shaft to stop it from spinning. Once the impeller is off you can remove the volute (rear housing) and change the seal.
Let me know if you need more help.
Feb 29, 2012 | Home
Have a Sta-Rite 1.5 hp Model #HMSF 1F - trying to get it apart to change seal- has been leaking and losing prime- four bolts hold the motor on- tried to separate there first but will not pull apart (maybe...
Remove impeller housing cover. Insert screwdriver carefully into back of motor to keep the armature from turning then unscrew impeller clockwise or opposite the direction of operation. Replace seal on impeller and pump housing. Lube seal with graphite. Replace impeller and housing cover. Remove screwdriver from motor. You should be good to go.
Sep 10, 2011 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
I have a Yamaha yz 125 2003 and there is water leaking out the bottom through a small whole and was wondering why it is doing that as it has just started doing it recently
This is telling you your oil and water seal need replacing ASAP do not ride until fixed as you will seize bottom end guaranteed !
there is small seal each side of your water pump impeller when you take the impeller out replace both even if only one needs doing as you will be going back to replace the one left soon after as they always go together..
Most people would not do this repair without replacing the impeller as well - usually the impeller starts to wear groves where it spins inside the seals then damages the seals So you get the theory behind replacing the whole lot as old impeller can damage your new seals
The seep hole is designed to give you warning of burst seal before its way to late as without the seep hole leak you would have no idea you are leaking coolant into the motor
You can do your self its a bit of work but not complicated - if you do your self don't forget to change your engine oil couple of times after first few rides reduce any risk of having coolant inside it where it should not be
good luck regards Jamie
Aug 29, 2011 | 2003 Yamaha YZ 125
I have a proline 1.5hp pump need to replace the shaft seal. I can't seem to get the plastic impeller off. We use a screwdriver to hold the shaft screw and try to turn the impeller counter clockwise...
Keep trying - It is stuck and will likely break but you have to remove it to change the seal. It is not uncommon to need to replace the impeller when the seal fails since the water gets behind the impeller shaft and rusts the metal causing the impeller to bind. If you still cannot get it free pull the motor thru-bolts and lock the rotor once removed from the motor in a vice. Use a large pair of channel locks to break the impeller free...replace it if necessary.
John
May 15, 2011 | Waterway 1.5hp Hi Flo Above Ground Pool...
Trying to replace seals for a hayward sump pump and can't remove inpeller
Thank you for posting your question here on Fixya.com.
Removing the impeller requires you lock the shaft as you turn the impeller off counter-clockwise. You will also need to check for an impeller screw in the center of the impeller inlet. If a screw is present they are usually left hand thread. Back out the screw first, then proceed to remove the impeller.
To lock the impeller you will have to remove the motor end cover or a cap covering the shaft end depending on which version your particular motor has. Look at the end opposite the pump and imagine a shaft from one end to the other right in the center.
Once you remove the cover you will see a slot for a screwdriver, a flat for a wrench, a hex hole for a hex key or some combination of these. Lock the shaft and spin off the impeller. Some are so tight you will end up breaking them in the process. Simply replace it and the seal. Be sure the motor shaft is in good enough condition to allow the new seal to work properly. If too much shaft material has rotted away the new seal will leak soon after it is installed; you would need a new motor at that point.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
May 14, 2011 | Hayward 1 Hp Super Pump Inground Swimming...
I have a Kitchenaid dishwasher KDS18. How do I replace the TANK SEAL at the bottom of the door? Do I take the door off to replace it? Thanx
It's always best to remove a door to replace a seal. Lay the door on a hard flat surface so there isn't any twist in it. Remove the old seal and install the new one.
May 13, 2011 | KitchenAid Dishwashers
How do I remove the pb460 booster pump in order to install the new one? Does the water have to be turned off from the pool?
You are trying to remove the pump so you can replace the impeller correct?
To remove the impeller you do not need to remove the whole pump. Turn off the electric first. Then just remove the several bolts and separate the back half from the front. Then disconnect the electrical from the motor and your can pull the motor with the seal plate, and impeller all the way out and work on it. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tailpiece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under one of the components (not sure exact part off top of my head have to look at it) and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Make sure replace the shaft seal, and use a tiny bit of pool lube on the rubber parts when installing, but keep the white and black ceramic surfaces 100% free of any dirt, grease, etc while working with them
Sep 17, 2010 | Polaris Pb460 Polaris Booster Pump...
IM TRYING TO FIGURE OUT HOW TO REMOVE IMPELLER TO REPLACE SEAL 2001YZ 125 LEAKS WATER
The impeller screws onto the impeller shaft. Go to the site below and you can see a parts diagram. You will select the brand, year, model, etc... It has the part numbers and prices.
http://www.babbittsonline.com/pages/parts/viewbybrand/1/Yamaha.aspx
There are actually two seals. Are you sure the leak is a bad seal and not the water pump gasket or a cracked/broken housing cover?
Please post a top rating for this solution. Thanks! :)
May 19, 2009 | 2004 Yamaha YZ 125
Pump seals
The impeller is threaded on to the shaft. The trick is to hold the shaft in order to untread the impeller. The surest method is to disassemble the back of the motor, exposing the opposite end of the shaft. There should be a spot to put a wrench in order to hold the shaft immobile. Then, it's simply a matter of unthreading the shaft. A strap wrench does a great job of holding the impeller without damaging it.
Dec 04, 2008 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
AO Smith 1.5hp Pool Pump Motor 2 Speed Ao Smith Electric for Motor Pool & Spa Pump Bn34 Logo
335 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
