Question about Saws
Carb settings to start partner k1250 - Saws
2 Suggested Answers
  • 11 Answers
SOURCE: What is the guel mixture for the Partner K1250
50:1
Posted on Jul 25, 2011
When cutting i think the engine is getting hot how to adj the carb
The K1250 only has a low speed adjustment screw, the main jet is fixed, if the machine idles ok there is no other carb adjustment that can be made.
Jan 19, 2013 | Husqvarna Partner K1250 Cutoff Saw Air...
Husqvarna k750 partner starts and runs fine up to limiter but will only idle for a few seconds then dies
I had a saw with a similar problem. I beleive you need a new carberator. I changed mine and my saw never ran so good. I think from all the vibration all the shafts/bushings have wore and now air is being sucked in from too many unwanted places keeping enough vacume to **** the gas out of the carb bowl.
Sep 24, 2012 | Husqvarna Partner K650, K700, K750, K950,...
Looking for the intial setting for the 2 screws on side of carb on k750
Hi, most, if not all chainsaws start with both hi and low screws set at 1 and 1/4 turns out, but when you turn the screws in, don't turn them tight-soft metal! Mark the screwdriver and turn them out , once chainsaw started the high speed screw can be turned in one eighth. The tickover is turned in just enough that sounds right and the clutch isn't engaged!
Aug 03, 2012 | Husqvarna Partner K650, K700, K750, K950,...
Partner k650 wont start when warm
This is a pretty common carb issue, the needle in the carb is leaking, if dirt has been throgh it then the needle seat will be worn, the only answer to this is a new carb unfortunatly.
Jul 08, 2012 | Husqvarna Partner K650, K700, K750, K950,...
I have a partner k700 was running fine ,and now no spark. any ideas
sounds like the coil went bad or the kill switch wire grounded out
Jun 03, 2012 | Husqvarna Partner K650, K700, K750, K950,...
I changed fuel filter ,fuel line to carberator ,rebuilt carberator and adjusted properly put new mixed fuel and coil is new and gets good spark motor has compression motor fires and stops runinng riteaway ...
Are you sure you pump in the unit properly? Some carbs have the gasket against the carb body and some have the pump next to the body. Also check the needle valve for proper operation,and dirt.
Jan 20, 2011 | Husqvarna Partner K1250 Cutoff Saw Air...
I have a partner k1250 cut off saw and there is no spark going to the spark plug. The switch is on, and I put a new spark plug in. Do you think it might be the coil. Rich
first make sure the switch is good and the wires are not grounding anywhere this is cheper fix then a coil when the switch is bad
start simple and work up
good luck
pat
Sep 17, 2010 | Husqvarna Partner K1250 Cutoff Saw Air...
Saws Logo
76 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
