Question about Garden
How do you change the air beam motor - Garden
Headlight low beams won't work
It could be the relay! It is most likely is located in the engine bay . could have dust in the relay plug . try using compressed air on the relay plug next time you are at a servo. Also you should heard the relay click when the low beams are switched on.
Dec 30, 2014 | 2002 Ford Focus
Beam BM1386 AB need to change belt but can't find manual
Not familiar with the beam model but they are all the same. Take off the shield that is covering the beater brush and you will see the groove and the diver motor where the belt was. Slide it on and put the cover back on and you are done.
Aug 04, 2014 | Beam Rugmaster BM1386AB Belt
Easiest way to change out low beam headlight on left side on a 2006 chevy trailblaser
Easy, remove the air cleaner top and move the air filter out of the way, walla, you now have tons of room to change all the bulbs on that side.
Dec 05, 2010 | 2006 Chevrolet Trailblazer
Change Headlight Bulbs
You have to remove the air intake filter and then kind of reach around up in there to change it. It can be done, but is a lot of work. Then you can just sort of reach in and change both headlights. A very big pain to change a couple of headlights. Make sure not to touch the glass on the light because the oil on your skin can cause it to fail sooner. HeadLight (Low Beam) H11 HeadLight (High Beam) 9005 Thanks -david
Nov 10, 2010 | 2008 GMC Sierra 1500
I need to change the low beam headlight bulb
  1. Remove headlight mounting bolts and nut
  2. Remove assembly
  3. Install headlight assembly (with new bulb)
  4. Replace/tighten headlight mounting bolts and nut
Oct 30, 2009 | Hyundai Motor 2003 Elantra
Head lights will not turn on.
The relay for the headlight is stuck locate it and replace it. Get a cd repair manual on Ebay motors to locate the electrical component.
Jul 08, 2009 | 2000 Chevrolet Cavalier
Main fuses for the horn and air bag
Fuse #8, #18 and #22.
Below is a listing of which fuse corresponds with which circuit:
1 - 10 Amp - Transmission Controller, Gauges, Autostick
2 - 10 Amp - Right High Beam Headlight
3 - 10 Amp - Left High Beam Headlight
4 - 10 Amp - Radio, CD Player
5 - 10 Amp - Washer Motor
6 - 15 Amp - Power Outlet
7 - 20 Amp - Tail, License, Parking, Illumination Lights, Instrument Cluster
8 - 10 Amp - Airbag
9 - 10 Amp - Turn Signal Lights, Turn Signal/Hazard Indicator
10 - 15 Amp - Right Low Beam
11 - 20 Amp - High Beam Relay, High Beam Indicator, High Beam Switch
12 - 15 Amp - Left Low Beam Headlight
13 - 10 Amp - Fuel Pump Relay, Power Train Control Module
14 - 10 Amp - Cluster, Day/Night Mirror,Sunroof, Overhead Console, Garage Door Opener, Body Control Module
15 - 10 Amp - Daytime Running Light Module (Canada)
16 - 20 Amp - Fog Light Indicator
17 - 10 Amp - ABS Control, Back Up Lights, Daytime Running Lights, A/C Heater Control Cavity Fuse Circuits
18 - 20 Amp - Power Amplifier, Horn
19 - 15 Amp - Overhead Console, Garage Door Opener, Trunk, Overhead, Rear Reading, and Visor Vanity Lights, Trunk Release Solenoid, Power Mirrors, Power Door Locks, Body Control Module, Aspirator Motor
20 - 20 Amp - Brake Lights
21 - 10 Amp - Leak Detection Pump, Low Rad Relay, High Rad Relay, A/C Clutch Relay
22 - 10 Amp - Airbag
23 - 30 Amp - Blower Motor, ATC Power Module
24 - 20 Amp - Power Window Motors
25 - 20 Amp - Power Door Lock Motors, Power Seats
Apr 02, 2009 | 2004 Dodge Intrepid
How to change bulb on drivers side low beam head light
My niece has a jimmy, they should be the same. The inside should be the high beam, the outside the low, DO NOT TOUCH THE GLASS ON NEW BULBS! Oil will cook on them and pop them! Both come off the same way. Take off the big rubber thing. They are soft but over hard plastic. Just pull them off. If you have trouble, you can flip the little wire clips that hold the headlight housing in place, this will give you room to see the rubber caps enough to figure them out better. The bulb assembly rotates CCW counter clockwise, and should slip out easily. Take the wires and plug off. it should be obvious how it pulls off. Snap the new bulb into the wires without touching the glass part. Gently replace in backwards order as you removed it. Put the rubber caps on, they keep water off the bulbs. It will break them!
The passenger side was harder for me. I had to take the air cleaner off, the whole cover and filter.You should be able to see or feel the same type caps, The low beam outside, High beam inside. The same 2 wire clips are there to release the housing. Everything pretty much goes the same, other than the air cleaner has to be removed and replaced. And make sure the rubber cap is replaced! Good Luck and good motoring!
Dec 15, 2008 | 2005 Chevrolet Trailblazer Ext
HEAD LIGHT ON 1995 DODGE
It sounds like you have a faulty high beam/low beam selector switch, if your headlamps aren't blown both on the low side. In order to change it, you also need to pull your steering wheel off, and it is also a part of your derictional switch assembly. Be aware if you have an air bag in the wheel, and if you do find out what you need to do first before disconnecting it, as some vehicles equiped with air bags can go off when you unplug or plug them.
Dec 15, 2008 | 2006 GMC Envoy
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
